Grease type for Dexter EZ lube hub?
What grease is everyone using for doing the EZ lube grease job?
Does Dexter recommend the same as NuCamp..that being the Valvoline?
Thanks!
Toronto, Canada
  • Denny16
    Denny16 Posts: 5,430
    If,you have not repacked the bearings, and it still has factory grease in them, I would go with the nüCamp recommendation.
  • @CanadianTabber -nuCamp uses Valvoline Multipurpose GM to grease the bearings.
    Here is their manual.  And page 57 at the bottom approves of nuCamps choice.
  • manyman297
    manyman297 Posts: 1,436
    I believe Dexter recommends any lithium complex grease with NLGI 2.0 consistency. These standards are usually clearly marked on grease tubes. I used Lucas red n’ tacky which is slightly more expensive but a tube will last you at least a couple of greasings. Valvoline is also very good.
    2021 400 BD
    2020 Tacoma TRD Off-Road
    ScottG Posts: 5,688
    It's worth shopping around. Last year I got a 10-pack of Mobil 1 Synthetic for $63--which IIRC was a pretty good price per tube at the time. (Of course, now that same 10-pack is $86...).
    I figured I'd just buy in bulk so I wouldn't have to ask this same question every time I wanted to add grease or repack my bearings.  :-)
  • Buckster
    Buckster Posts: 62
    After researching and shopping around, I decided to go with Sta-Lube Sta-Plex Extreme Pressure Premium Red Grease
    2022 T@B 320 CS-S Boondock
    2018 Nissan Frontier 4x4
    SW Ohio
  • Slackers
    Slackers Posts: 490
  • ChrisFix
    ChrisFix Posts: 743
    edited July 2023
    Any Lithium Complex grease will work, and is compatible with the factory installed grease. You want the NL
    GI rating.
    Lucas Red "N" Tacky is very popular for axle bearings, and is what I've successfully used for many miles now.
    https://www.walmart.com/ip/Lucas-Oil-10005-Red-N-Tacky-Grease-14-oz/36052506
    You do not have to use Valvoline, but of course that would work too. Remember to keep the tire spinning while you pump in the grease, and keep pumping grease in until new grease starts to come out. If you're doing it for the first time with the Lucas...you'll have the nice red grease to signal when you're done.
