Hello all,
We're into our 2nd year with our 2022 Tab400 with its dual 6V AGM batteries. Last year we were delighted to find that we could go 2 or 3 days dry camping relying on our battery and solar combo. This year however, we noticed that after one cloudy day and our battery power drops dramatically to well below 10V causing a scramble to keep our fridge running.
Our trailer was stored outside, covered for 8 months (Oct - Apr) last winter (Ottawa, ON) with the battery disconnected from the solar.
Did we wreck our AGMs?
Glen & Karen | 2022 T@b400 BD | 2017 Toyota Highlander | Ottawa, ON CANADA
0 ·
We just got back from a weeklong trip in a very shady site with little solar gain. We are pretty frugal with our electric when in shady sites but still used our inverter and 800watt drip coffee pot each morning. The lowest our batteries got down to was 82%. On that day I did hook up our portable solar panels to help get them back up to 90%. But we do have the 3-way fridge and run it off of propane so we don't have the large electrical draw that your fridge will have. Another reason I do like the propane fridge. With the compressor fridge you may want to upgrade to at least 2 lithium batteries. Going to 1 lithium won't give you any more usable power that the 2 AGMs gave you when brand new.
I took the batteries out this afternoon and will have them tested tomorrow to see if we've done any damage. I hope it's just us learning to manage things on cloudy days. If we have to go to a portable solar panel or lithium down the road to keep boondocking, then so be it.
Enjoy your travels!
2022 T@b 400 BD
Ottawa, ON
The only thing is now I can't get the VictronConnect iPhone app to find the solar controller. I've been through all the usual Bluetooth steps but can't detect it. I tried another phone, still not picking it up. Am I going to have to pull out that drawer and hit a reset button?
Any advice would be appreciated.
Keeps me out of the malls, I guess.
I'm still recovering from having to stick my head and shoulders in the back of that drawer cabinet but I can finally see the controller on my phone. I had to undo the mounting screws and the one wire support to get at the controller though. Pulling the fuse alone didn't cut power totally so I disconnected the negative side for the PV then battery, reconnected battery then PV and voila!
Now for a beer then put everything back together.
Thanks to all for your help.
- 2 AGMs should deliver 220 amp-hrs or 220x12= 2640 watt-hours
- maximum discharge of 50% means we have 1320 watt-hours usable charge
- our Isotherm CR65EL fridge uses 23 amps over 24hrs or about 12 watts per hour
- so if the AGMs were performing as expected, I'd expect about 110 hours with just the fridge running
- adding in the water pump, occasional LED lights and other never-off items like radio and detectors, I should be seeing about 4 days without any solar input at all
4 days is definitely not what we're seeing so my concern once again is still we've damaged our AGMs despite what our local battery store says.
Am I missing anything?
2020 Tacoma TRD Off-Road
Your estimate of frig power consumption is too low. The DC refrigerator uses about 7 amps when running. (You should confirm in their documentation. If given in watts, divide by 12). Depending on how hot it is, let’s assume it’s on 10 hours a day. That’s 70 amp-hours. You only have 110 amp-hours available (using the 50% rule).
For pthomas745:
Yes. I only recently started using the Victron app. Last year, our 4-dot gauge never went below full but this year things seem to have changed so I downloaded the app. During our recent trip, after a day of driving, the Victron app showed a full charge of 12.7V. By 6am, it was about 12.4V and by 6pm it was almost done at about 11.5V.
Are you taking voltage readings with the battery switch off, and no solar charging coming into the trailer?
That day, the battery cut-off switch wasn't engaged because we wanted the fridge to run. The weather was very grey so not much solar would have been added.
For other commenters about the 12V fridge, here is what I've found on the power consumption for this model of 12V fridge:
Power consumption: 290W/24hrs with "instantaneous" consumption of 5amps at 12V (I assume that means when running).
What I'd like to do is more testing myself. I can cover the solar panel to simulate a day of low or no solar input, flip the battery cutoff to the trailer and watch with the Victron app how the batter voltage drops. Hopefully that will isolate the battery performance.
Just to confirm, are you referring to the "Charger enabled" toggle on the Settings page in the app? Flipping that will stop the solar input?
I think the 2.5amp value is incorrect, or is assumed an average over 24 hours. Their technical data shows 6 amps when running (instantaneous consumption), but they also state it consumes 275W of power over 24 hours, which doesn't make any sense. 275 WHours over 24 hours would make more sense, but that then assumes the frig only runs for less than four hours per day, which is extremely low. I think a good assumption is 10-12 hours running at 6 amps is typical for these 2-way fridges, which equates to 60-72 Amp-hours per day. This would better match the behavior you're seeing with low solar energy.
See page 52 of their tech data.
https://www.indelwebastomarine.com/fileadmin/webasto__media/indelwebastomarine.com/INT/Documents/cr_classic-elegance-inox-inox_clean_touch_manual.pdf
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
In the meantime, AnOldUR: I'm curious how you're using your NOCO Genius10 to top off your batteries. Are you digging out your batteries from under your bed or do you have another way to connect?
So in the end, what was causing the reduced battery performance that started this thread? Was the Victron solar charger not turned on, or is it just a better understanding of solar performance on cloudy days?
