Has anybody been successful in streaming downloaded shows from the iPhone Netflix app to the TV via the Apple HDMI adapter? When I try it I don't get any audio to the Jensen via Bluetooth. This is with the Apple HDMI adapter plugged into the TV HDMI port and the sound sent to the Jensen via Bluetooth. I've downloaded shows on both the Amazon Prime app and the Netflix app. The Amazon Prime app shows allow me to transmit the audio to the Jensen via Bluetooth, but the Netflix app has no option for that and I get no audio. Any suggestions, other than only watching Amazon Prime downloaded shows?
Rich
2019 T@b 400
Bellingham WA
0 ·
I think when you disconnect the HDMI adapter from the television to plug in the Apple adapter, you lose HDMI ARC or the pass through. I tried a splitter and Bluetooth to the radio and got tired of messing with it. I use a cheap sound bar connected to the headphone jack on the tele. It works fine for me.
Jeff & Amy
2020 T@B 320 Boondock
2020 Subaru Ascent
Bainbridge Island, Wa
Trips - 48 Mileage - 63,452
Tampa FL
On a related note, ASA replaced my defective TV remote so now I could turn on the TV sound if I wanted to.
4K HDMI Cable 6.6 ft, iVANKY High Speed 18Gbps HDMI 2.0 Cable, 4K HDR, 3D, 2160P, 1080P, Ethernet - Braided HDMI Cord 32AWG, Audio Return(ARC) Compatible UHD TV, Blu-ray, PS4, PS3, PC, Projector
and
USB C to HDMI Adapter (4K@60Hz), CHOETECH USB Type C (Thunderbolt 3 Compatible) to HDMI Adapter Cable for Samsung Galaxy S10/S9/S8/Note 8/9,MacBook Pro/MacBook Air/iPad Pro 2019/2018, Dell XPS 13/15
the cable plugs into my phone charger port, plug one cable into the other cable, then plug cable into the HDMI ARC on the back of the Jensen TV (requires unplugging plug from Jensen receiver which uses that HDMI ARC port). You now mirror the phone screen, and can stream netflix or amazon prime or any video through the phone.
Then, set Jensen receiver to bluetooth, and you get audio through the speakers.
happy camper...
I thought that using an HDMI splitter would work. From FireStick, split to (1) the television, and (2) the Jensen unit. Didn't work. (The USB port on Television did work well to power my firestick).
My work-around to get the sound out of the "house" speakers was to use a 6ft long male-to-male AUX cable from the headphone jack of the Television (far right as viewed from below), to the aux port on the right lower side of the Jensen receiver. Not particularly elegant, but it works flawlessly.
https://www.amazon.com/dp/B01EHSX28M/ref=cm_sw_r_cp_apa_i_G4LsFbQS1V94Y
This worked on my 2019 T@B 400, but would assume it would work on any Jensen system that has Bluetooth.
Have you ever heard of "Watch Netflix or Money"? It's a helpful resource that can save you from searching through apps and settings. You can quickly check if the show or movie you want to watch is available in your region before going through all the hassle.
