Hello:
The truck does not charge the lithium battery to the RV when traveling, but the battery charges when hooked up to shore power or the solar panels. We arrived at our camp spot with barely any power. I’m wondering what could be the problem? All the fuses and the 7-point plug on the vehicle seem to be good. The converter was changed to a lithium compatible WFCO model. Any thoughts? Thanks
1 ·
We have a 2018 Boondock 320
Have you checked your 7 pin voltage on pin # 6 (the charge wire)?
Found this online, but not sure if it's generic to all tv/trailer combinations?
I will check the charge wire at the 7-pin. This particular issue seems to be specific to the new lithium battery. We did not have this issue with the lead acid.
I also read somewhere else the following:
Modern vehicles have a “smart” alternator that only charges the car battery when the vehicle computer determines that the battery needs juice. Sometimes these smart alternators don’t play well with trailer batteries because they either don’t detect the need to charge the battery or they trailer battery isn’t low enough to need the charge.
When we ordered our camper, we upgraded the battery charger/controller specifically to avoid this problem. The battery controller is programmed to always tell the tow vehicle computer “battery needs juice” so we don’t have an intermittent charge/no charge problem.
https://www.amazon.com/OrionMotorTech-Battery-Connect-Disconnect-Recovery/dp/B074J5DS33/ref=sr_1_5?keywords=30+amp+quick+connect+plug&qid=1692543542&sprefix=30+amp+qui,aps,161&sr=8-5&th=1
Personally I always start with a fully charged battery and the tow vehicle can easily keep it topped off while driving.
I concluded that both TV (~6A) & solar (~5A) were contributing a charge current.
PS: Our TV battery is connected directly to the 7-pin socket.
note that my old Wrangler does not have an isolation relay, the charging pin is always hot.
Edit to say that the picture below may be a good alternative. Anyone want to point out the charge wire?
Southern Maryland
Ken / 2023 Tab 400 “La Bolita” (20,000+ miles) / 2024 Toyota Sequoia
2024 - 1 Trip - 20 nights - 3 National Parks, 2 National Forests
At one point , I was looking to do the same in my Grand Cherokee after I installed lithium batteries. I chased down the wiring diagram for my WK2 and found a dedicated line from fuse #30 /30A to the 7 pin…maybe your model is the same??.
Southern Maryland
@Yoshi_TAB. We also tow with my wife's Cherokee Trailhawk. I'll bet we have the same dedicated line from the fuse box.
@elbolillo. After Jean helped me out with the colors we were pretty sure it was the second from the right in the picture like you said. Thanks for confirming.
Question, there are three other wires at that connection, two more red and one black. My guess was one wire going directly to the battery for charging and one going to the cutoff switch to supply 12V power to the trailer. This would allow the trailer battery to charge regardless of the switch position? Even if that is correct, it leaves the question of where the forth wire goes?
What I want to know is if simply disconnecting the wire from the 7-pin harness will mess up something else?
Might have to contact nuCamp, but hoping for a quicker answer from the forum.
The four wires are for 1. From battery charger from the WFCO. 2. On/Off battery switch 3. Trailer Electric brake power 4. Trailer tow harness.
Southern Maryland
Also, my tow vehicle has a heavy duty alternator and charges/supplies 5.5 amps (~72 watts) to my T@B with no DC-DC controller necessary. It runs my DC fridge and has enough left over to top off and keep the batteries at 100%. I have a 25 amp switch/breaker on the feed at the battery.
2023 Ford Maverick XLT
The Finger Lakes of New York
The bottom right wire (not sure of color) traces out to the emergency brake switch. One of the two (red?) on top goes to the battery switch so that if it's on, the emergency brakes will be engaged if the pin is pulled. The other goes to the WFCO so that when on shore power it will always charge the tow vehicle battery (if plugged in), but only charge the trailer battery if the battery switch is on.
All this to say that removing the black wire will isolate the tow vehicle battery from the trailer.
Southern Maryland
Southern Maryland
