I am a new user of the keder rail on my 2018 t@b 320s and was struggling to attach the keder insert pahaque side tent and a canopy to which I sewed 8mm keder insert. (Not at the same time of course.) i tried the tip of using a few drops of dish detergent and that helped but I knew the ‘slide” should be easier. Then I had an ah-ha moment and checked the screws attaching rail to t@b. Most needed tightening and after doing that, I was successful in quickly attaching either to my t@b. Now I’m ready for my next adventure to Texas’ Fulton Beach.
2018 ‘Sylvie’ t@b320s
TV 2016 Toyota Highlander 6 cyl with towing pkg…whatever that means
4 ·
I understand this helps to use the rail- I own it, but haven't tried it yet. Well reviewed by others (sailors!).
https://www.amazon.com/Super-Lube-11016-Aerosols-Dri-Film/dp/B000RFRM4U?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=ATVPDKIKX0DER
2020 Audi SQ5
I used a square bit that had a small shank so it fit in the keeder rail easily then I used a 1/4 countersink bit and got all the screws flush.
So Nice. Should have been a factory detail for sure.
2021 CS-S - Enjoying the new layout
2011 Outback 3.6r
