When my dometic fridge is cooling on propane the needle on the gauge does not move into the “green” portion, needle stays far left. The fridge cools well on propane and would be nice if the propane indicator worked. Is this an easy fix for a DIY task? It is under warranty but hate to take it in for this issue.
2020 TAB 320 U
TV 2025 Telluride X Type
0 ·
If you have a Dometic - - - Please provide the Fridge Model Number.
Norcold N180.3 controls look like:
1] meter defective
2] thermocouple defective
3] bad wire terminal connection.
Since the Flame Meter is sold on Amazon good chance that is the failure point. Replacing it should not be a big deal, removing stove top will provide access to back side of Fridge Control Panel.
Adventures: 58 Nights: 405 Towing Miles 50,180
https://tab-rv.vanillacommunity.com/discussion/11707/propane-flame-indicator-problem-norcold-n180-3
From what I could see, the blue wire is going to be the challenging one to get off and the new blue wire attached.
Having the same issue.
2019 320 Boondock Edge - Sold Jan 2022
the fridge seems to work on propane but the meter is not functioning ( have a new one)
can anyone guide me on how to install the new one? Do I lift the stove up?
Thanks in advance!!
greg
= 1 = Lift glass stove top cover.
= 2 = Pop-off the Four (4) rubber glass top stops {they cover the mounting screws}
= 3 = Remove screws.
You now have access to the Fridge top surface and rear of Front Control Panel.
= 5 = Believe the Flame Meter (11) is held in-place by two screws (17) with washers (16)
{based on parts list diagram, below}
I did it today, all went well, just need abit of silicone around the propane stove
the blue wire is the most challenging!!!
