When I brought my '23 T@B 400 home, the freshwater tank showed 1/3 full, which I assumed was for demonstration purposes in the walkthrough. Last week I winterized and dutifully followed all the written instructions and watched the nuCamp video multiple times for the process. I had no obvious problems. However, the control panel still shows the freshwater tank as being 1/3 full. Am I missing something obvious?
                2023 T@B 400 Boondock, 2022 Toyota 4Runner SR5, various telescopes
0 ·
The winterizing process using the Nautilus requires the Nautilus valves be in the "winterizing" position. If you did that, the process won't pull from the freshwater tank at all.
SW Montana USA
2023 T@B 320 S Boondock
You may want to clean the vent, just in case. See thread with pics here:
https://tab-rv.vanillacommunity.com/discussion/11129/dont-let-this-happen-to-you-blocked-fresh-water-tank-overflow-with-nautilus-system#latest
Well done.
Does "had" system installed mean you found a technician willing to do the project or was it DIY?
I really like the SeeLevel tank monitors (factory installed for my yr-2018 320S) and was disappointed when nüCamp switched to the known poor performance KIB units.
As a newer TaB might be in my RV future I investigated doing the tank monitor upgrade DIY.
We have access to all the tanks for the sensor strips and it appears the KIB wiring between the
sensor location and display panel can be used. So real issue is the mounting of the SeeLevel display.
I do wish there was a way we consumers could influence builders to use quality sub-systems in
their products. While nüCamp does far better than most RV Builders on trailer itself build
materials and craftsmanship they unfortunately seem inclined to select more lower quality
sub-systems as their product lines mature. Or make design choices that reduce the oriignal
trailer's usefulness - - primarily reducing storage space with the ducted Air8 AC for example.
It is possible to now purchase a 320S with only rear cabinet storage as the front (over stove)
cabinets are smaller, the once huge under passenger side rear seat space has the air8, and
if the super solar/lithium package is purchased the passenger wheel well seat storage is gone.
The older design window AC (instead of a microwave oven) and having all batteries outside,
not in the cabin is far more useful IMHO.
2020 Tacoma TRD Off-Road
