I have a 2015 T@B 320S that has been much loved and well used......72,000 miles worth. After returning home from a recent six week trip and washing mud from under the T@B, I noticed a cover hanging down. It is located in front of the driver's side tire, and appears to protect the p-trap and some wires there. It has been held in place by several screws, which let loose, as well as some black caulk adhesive.
Has anyone had this problem? What kind of caulk adhesive was originally used by the factory? Any advice would be appreciated.
2015 T@B 320 S, 2019 Jeep Cherokee
0 ·
Is the compartment above wet? Does the cover look like it had water in it? Could it have been hit by something? Why did the cover come off?
Then I would use butyl tape or a bead of marine silicone sealant on the flange the screws pass through. You may need to repair the screw holes or get larger diameter screws if the old ones just pulled.
The area above the cover is not wet, and the shower has not been used in over a year. But it is sort of a mystery why the cover came off.
