See thread here:
https://tab-rv.vanillacommunity.com/discussion/comment/189533#Comment_189533It seems my coupler is shot, and I'm wondering if anyone else has had experience replacing the coupler. I have a few questions for the Nucamp techs, but I have a message in with them and am waiting for a call back.
I am looking at one of these for a replacement:
https://www.tractorsupply.com/tsc/product/reese-towpower-coupler-2-in-a-frame-e33305030333https://www.tractorsupply.com/tsc/product/bulldog-a-frame-collar-lok-coupler-2-in-ball-size-primer-finish-7-000-lb-capacityThe Bulldog is much more heavy duty, and is a sleeve-style coupler. Does anyone have experience with these? Are they easier to operate? Worth the extra money?
It appears the Tab coupler is bolted on, rather than welded. These couplers are pre-drilled to bolt on the jack, but not to bolt onto the frame. I can drill the holes on the new coupler, which I believe are 3/8 bolts, but how many lbs of torque should be applied to these bolts?
Any other considerations here?
I will update this when I hear back from Nucamp for future reference.
St Catharines, ON
North Georgia
North Georgia
St Catharines, ON
If you are chocking your wheels, bumping the trailer forward a couple of inches, and the coupler still won't unlatch I don't know what to suggest other than maybe you have a defective or damaged coupler.
2023 T@B 320 S Boondock
@bjn2 I'm happy you found something that works well for your usage
Did you get a Demco coupler for your T@B yet?
TV: 2023 Ford Bronco 2.7L Wildtrak 4x4, Tow Package, Ford Brake Controller
Georgia
Georgia
Ultimate trailer jack is on my watch list. Will see how the coupler goes in first. I'll update here or a new thread.
Georgia
https://tab-rv.vanillacommunity.com/discussion/17912/demco-ez-latch-coupler-upgrade-tab-320-bd#latest
Georgia
https://www.etrailer.com/Trailer-Jack/Ultimate-Jack/322-RDJ-2K.html?feed=npn&gad_source=1&gclid=CjwKCAiAvJarBhA1EiwAGgZl0GclHDvDUv9y1Eoms5oIXUB2SdmI5k4pd5jYuJdH71zUgdqD0CyCdBoC4W0QAvD_BwE
