So, we were happily driving from Chandler, AZ down to Tucson to do some camping with our daughter in her 400 (her Youtube channel is Amelia Away if any of you want to follow her travels). We were in the right lane and a semi was passing us and something got louder. We thought "that semi has a weird noise". A second later, our low tire sensor started beeping rapidly. Uh oh. Pulled off to the side of the road and found the left side (facing the travel lanes - why is it always that way) was blown out and water was pouring out of the Alde cold water drain. Uh oh again. Managed to get the tire changed with the spare after fooling around with a couple jacks. Pulled off at the next exit which would have been too far to nurse the camper to on the flat and assessed the underside. No obvious damage to the wheel well or surrounding structure. Phew. Went inside the camper (Max S - What is called a 320 now) and looked in the Alde compartment. No damage. Phew again. The vibration from the tire going flat must have vibrated the release valve up. Push it down and now that we are at the campsite, all is good. No leaks. Called a Discount Tire near the campground and they worked us in. We were in and out in a little over an hour. Great service. We replaced all three tires to make sure all was good. We camp a lot so this was good for peace of mind.
Some thoughts.
Bottle jack. A while ago, I bought a small bottle jack so it would fit under the frame with the tire flat. Guess what? For a 320 (not sure on the 400), If your bottle jack is small enough to fit under the frame when the tire is flat, it is nowhere near big enough to lift your trailer high enough to get the tire off. If you are relying on a bottle jack, test it by letting the air out of a tire and see if it fits and lifts high enough.
Don't just assume the jack in your tow vehicle will work. The scissor jack in our jeep was too tall to get under the frame with the flat.
Buy a scissor jack. One that collapses down very low but still has enough up travel. These typically have more "throw" than a bottle jack.
Hindsight, I thought about but didn't use the method of unhooking the camper, lowering the nose all the way, dropping the rear corner legs down then raising the nose. Figured it would have been a huge pain to do that but, in reality, would have been much easier and much more stable. As it was, I used our bottle jack to get it high enough to get the Jeep's scissor jack under the frame. Then I jacked it up the rest of the way.
Test your jack. The release valve on my bottle jack needed persuasion to release when it was no longer needed. A jack will do you no good if it does not work.
Weirdest part was that the inner inch of the tire tread had come off and wrapped itself around the axle. Had to do some yanking and threading to get it out. Safety first of course so I put the spare tire on the ground under the frame.
And the biggest thought. ALWAYS USE TIRE PRESSURE SENSORS. Had that not gone off, it would have probably taken us longer to recognize the issue. We were being passed by a semi so we though that was what was happening. Had we continued on for even another minute, the tire could have come apart more and done serious damage to the camper. I've seen horror stories of this. Get one that shows pressure and temperature and alarms with variances. If a tire is getting too hot, it is probably failing and it can blow. If you lose pressure slowly and don't know it, it can blow. I think ours was a rapid blowout since it was just a couple seconds between the odd sound and the sensor going off. The tires had lots of tread and no odd wear. Some sort of rapid failure or we ran over something.
Be prepared. I know some just use AAA and other services, but for those that don't, make sure you tire changing solution will work. Don't just assume. Like I said above, let the air out of one of your tires and make sure you can change that tire with what you have.
                2014 T@b S Max AKA T@dpole
3 ·
2020 Tacoma TRD Off-Road
All good things to think about.
On another note to consider...when/if using aftermarket TPMS sensors for your TAB, make sure your valve stems are metal and not rubber. The weight of the sensor on the end of a stem (if using that type vs. internal to rim) will cause a rubber stem to flex during high speed rotation, resulting in an unexpected failure of the stem. You can buy motorcycle after market sensors in pairs of two, but consider changing out to metal stems.
Southern Maryland
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
https://www.amazon.com/gp/product/B009BE069Q/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
The only jack that is properly safe and that has adequate lift is a floor jack. These should be placed upon a flat surface (I carry a small sheet of plywood) and used in conjunction with jack stands... Yes, they are bigger, heavier, not as "convenient as either the scissor jack or the bottle jack, but at the least, they are safe and can get the job done. There have been plenty of threads here that included specific recommendations for good and quasi compact floor jacks. Many of those included discussion about not using bottle or scissor jacks and also mentioned taking a deflated flat tire into consideration.
On the scissor jack vs bottle jack thing, if you can't get a bottle jack under your frame, they are worthless. If your bottle jack fits under the frame WITH a flat tire, then it doesn't lift high enough. Also worthless. You can do things to help stabilize the camper when changing a tire like lower the stabilizers, chock the tires, etc.
https://www.harborfreight.com/automotive/jacks-jack-stands/floor-jacks/2-ton-compact-trolley-jack-64874.html
The most important thing is to think about changing a tire before it needs to happen and get what works for you. Whether a scissor jack, floor jack or bottle jack. Test it out in at your house to make sure your tools all fit, the jack fits and you can do it safely.
Sold 2023 Tab 400
Sold 2018 T@B 320S
Thankfully - no damage to the TAB!
Good Sam sent a guy, who had changed a tire on another TAB, so he knew what to do. Thankfully, a tire store down the road had the right size in stock and after an afternoon waiting in their lot, I was on my way.
For the record, I was running Goodyear Endurance tires.
Sold 2023 Tab 400
Sold 2018 T@B 320S
I carry the same pint-sized harbour freight (aka Torin, Big Red) jack on trips as @bbberger. Fits deflated wheel.
However it does not quite lift high enough on my boondock on uneven ground.
Hence carry a necessary pair of 2x12x3 ft boards strapped to truck cap.
Tool kit includes half inch drive torque wrench, pipe for breaker bar action, socket, spare acorn nut, spare valve stems and caps, and small bottle of hand degreaser.
Also an infrared thermometer bought during our brake adjustment saga.
If you pull a wheel, check your electric brake wires for dangerous slack that could abrade on tire!
https://tab-rv.vanillacommunity.com/discussion/17161/why-did-why-will-your-brakes-suddenly-fail-on-one-side-lifesafety-issue#latest
Based on continuing 2023 postings about new trailers, nucamp continues to sell mismatched diameter spare tire rims and hoist mechanism end fitting. (Since 2020).
One must grind the steel dongle on hoist or the opening in rim, to remedy inability to winch tire up fully and parallel to underside of frame.
https://tab-rv.vanillacommunity.com/discussion/15120/fixing-spare-tire-cable-hanger-tip#latest
Anyone have comments on how they work? Is the signal strong enough to reach the tow vehicle?
TireMinder recommends metal valve stems, which I've had installed at Discount Tire on Goodyear Endurance.
TireMinders come with signal boosters which they recommend using. On the 320 with plastic middle tub, and 4Runner combo, I did not need the booster. Once I added the platform and aluminum center tub and side tubs, transmission was intermittent. I did not want to install the booster on the frame and wire it to a 12v source. Instead, I placed my Goal Zero 1000 in the back of the 4Runner, taped the booster to the window, and attached the clips to the red/black 12v output ports and it worked great! No issues. Now with the 400 (with side tubs added)/F150 set up, I place the Goal Zero in the backseat with transmitter taped to back window. It works but occasionally have the delay-I think I'll try taping it to the top of the window this year.
I use this to give me comfort; when I was new to towing, every slope on the road had me wondering if my tire was going flat. Now I can give a quick glance. I think this model of TPMS is on the lower end, and after five years, part of the screen is hard to see, but overall, I'm happy with it.
Sold 2023 Tab 400
Sold 2018 T@B 320S
"Just Enough"
Sold 2023 Tab 400
Sold 2018 T@B 320S
My view is as @ChrisK above feels....that the TPMS may see a problem coming & save a high-speed event from ending up badly. Just another step in managing risk.
SW Montana USA
