What do you consider to be your "Most Valuable" trailer mod?
12346»
  • Yoshi_TABYoshi_TAB Member Posts: 566
    edited January 2024
    Where can I find more info on the TAB 320 rear seat hinge mod? I have the newer split seat (2023 TAB 320 BD).
    Hi @sportcoupe
    Here is how I did this. The attached close up below may help. Please ask if anything was not clear. If you search the forum, there is a few other postings.  Others welded their parts.  I have found the screws hold just fine.
    The BOM was:
    -Square door hinge
    -Bar stock (3/16" thick),  1 1/2" wide.
    -Small screws
    -T-nuts
    -Wood Screws
    - Blue Loctite
    Tools: hacksaw, drill/bits, screw driver.
    1. Remove the OEM hinge from seat and wood. Save screws.
    2. Attach short piece of bar stock (#2) to door hinge and seat bottom wood frame using wood screws. You need to drill holes in the bar stock for wood screws to go through. Length of short piece not critical.
    3. Measurement of longer bar stock (#1) is important. It's cut to length so it fits between OEM seat hinge and door hinge.  Once the door hinge is attached to the seat, you can use the OEM hinge to get measurement.
    4. Drill holes in long piece of bar stock to match up with holes in both OEM seat hinge and door hinge.
    5. Attach long piece of bar stock to both hinges with scews, t- nuts and loctite
    6. Screw OEM hinge back into position in wood support.
    7. Repeat for all 4 sides
    https://youtu.be/gout5r-O3xU
    2025 360 CS
    Southern Maryland
    vshumate said:
    Is it necessary to use metal piece?  Couldn't say hard plastic be used?  In my mind there is not much pressure put on those metal pieces in either position.  Thanks
    Hi @vshumate
    A flat piece of plastic would flex too much if you use the seat in the upright position as a seat back.    In upright position , the bar stock  is supporting the weight as the seat is no longer connected to the OEM hinge.  If you never use the seat that way, you could just put a hinge on the back side.
    2025 360 CS
    Southern Maryland
  • fwunderfwunder Member Posts: 67
    edited January 2024
    2023 400 BD. Drawer space modified for cat litter box space. If the cat's not happy, nobody's happy!!  ;)
  • sportcoupesportcoupe Member Posts: 30
    edited January 2024
    Hi @sportcoupe
    The BOM was:
    -Square door hinge
    -Bar stock (3/8" thick),  1 1/2" wide.
    -Small screws
    -T-nuts
    -Wood Screws
    - Blue Loctite
    @Yoshi_TAB
    Did you really use 3/8"  thick bar stock or is that a typo?
    2023 T@B 320 S BD,
    TV: 2023 Ford Bronco 2.7L Wildtrak 4x4, Tow Package, Ford Brake Controller
    Georgia
    edited January 2024
    @Yoshi_TAB
    oops..it was 3/16" ..tks for catching that.  I'll update the original  post
    2025 360 CS
    Southern Maryland
  • SLJSLJ Member Posts: 641
    Me, my lithium battery upgrade. My wife, the bathroom fan addition...
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • manyman297manyman297 Member Posts: 1,433
    Installing a larger and deeper sink with residential faucet. I’ve done a lot more technical mods but this one is practical and is used every day we’re in the camper. Best bang for the buck.
    2021 400 BD
    2020 Tacoma TRD Off-Road
    On the major side of modifications, installing 400ah of LiFePo4 batteries, 3000w Victron Multiplus, SmartShunt, MPPT Solar Charger with external plugin would be number 1 for us. We no longer need to lug a generator along with us on our trips.
    The small modifications we have made, while small compared to the battery mod, nonetheless make our Tab more convenient for us.
    I swapped out the kitchen faucet for a taller, fold-down model that makes all the difference for washing dishes.
    I added a dimmer switch for the lights under the cabinet in the kitchen area.
    I installed a couple of fast-charging USB-C outlets.
    Installed a toggle switch to cut all power to the radio (And not have to pull the fuse)
    Installed a hinged door behind the dinette cushion, providing storage and support for the back cushion.
    Maxx Air fan.
  • grassgdgrassgd Member Posts: 160
    This is a hard question to answer.  Made so many mods, some were pretty major and some were easier to do.  I list one of each:
    First the major was to add a storage compartment to the front of the trailer to avoid all the trailer dedicated stuff from being carried in the tow vehicle.
    The easier was to add an LED light above the Alde Glycol tank and make the wood inspection board held in place with magnets and eliminate the wood screws to inspect the glycol level:
    2019 T@B 320S
  • FreespiritFreespirit Member Posts: 184
    On our last trip we fought with keeping our door open 90 edgers to enjoy the cool weather. Any little breeze would close it or open it all the way.  I like to keep the refrigerator vents clear of anything in front of them. Here is my quick and inexpensive solution.
    2020 TAB 320 U
    TV 2025 Telluride X Type
  • RomanaRomana Member Posts: 67
    Any detail on how you split the front cover and added the rectangular box in the middle? Looks fantastic!
    Romana - 2005/6 Thor T@B T16
    Port Townsend, WA
    @Romana, I ordered an additional door stop from Amazon, then used a scrap piece of 3/4 inch square wood stock and screwed the new door stops to the wood. Then my wife insisted I paint it blue to match the TAB. I think a better design would be to use a piece if 3/4 wood cut to size (2 1/2 X 3), then you would be able to screw both piece into the wood making it much stronger and less likely to split.
    2020 TAB 320 U
  • KK1LKK1L Member Posts: 117
    edited May 2024
    Sorry I see this thread is a few months old. I only occasionally check out this forum.
    @SLJ   Would you consider drawing out a schematic for this? The breaker is supposed to protect the wiring to the camper load. If you have one breaker for each battery, then you doubled the max current to the camper wiring. I am worried you created a potential dangerous situation.
    Jericho, VT
