Do I have a Boondock??
Hey all.  I have a 2018 T@B 320 S.  I purchased it in 2018 or 2019 from an RV shop where it had been traded in shortly after purchase.    As far as I know it is not a Boondock model.  BUT, the tires always seemed like they looked like Boondock tires.  I decided to take my T@B out of the campground where it has sat for most of the time since purchase so I can take it on retirement adventures and figured I needed to put on some new tires. Checking my tire size, and Westlake ST235/75R15 is the boondock tire size.   Silly to ask after this long, but do I have a Boondock model??  What else is different that would answer that question?
Kelly G
2018 T@B 320 S   TV: 2020 Kia Telluride
(T@B is New to me as of 8/30/2019)
Bloomington, IL
  • MuttonChopsMuttonChops Member Posts: 1,852
    Your tire size "R15" is the tire size used in 2018 on the Outback (Boondock) model . . . . and also on standard rigs that had the "pitched axle" installed as an option . . . back in 2018 nüCamp was very flexible allowing for customer requested changes.
    You could also measure the coupler height ( 'B' in figure ):
    BTW,  I have a special order 2018 . . pitched-axle, R15 tires, and front storage rack
  • KellyGKellyG Member Posts: 11
    Should add that I don't have the other obvious things like a roof rack or diamond plated boxes.
    Kelly G
    Bloomington, IL
    The floor was obviously different in the 2018 Boondock model. Factory specced Boondocks had slate grey Marmoleum flooring, while non-Boondocks have a brown, wood-look vinyl.
    The roof rack, tubular front platform, and aluminum front tub were also obvious features of that model. As MuttonChops mentioned, it’s not uncommon to find older Tabs with a mix and match of features as nuCamp was much more flexible about customizations. Plus, a lot of folks retrofitted these features themselves later on as parts became available.
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,020
    If the previous owner retro fitted a pitched axle, would the step height to ground be different?
    Yes Sharon, it would be.  We added the pitch Boondock axle to our TaB, and had to get a small step stool to make up the difference in height.
