Our 2020 320S came with a 100W flexible panel on the front part of the roof. The panel still works, but I've read that flexible panels lose efficiency over time. I'm tossing around the idea of putting a larger (200W?) panel in that location for more charging while on the road (we have a 200W suitcase for supplemental charging while camping). I have a couple of feelers out to find out if this is practical, but wondered if anyone here may have had this done and the cost involved.
I know that I'll have to replace the 75/10 controller, but I'm hoping that the existing wiring would be enough to support the additional current. Swapping the controller is something I can do, but taking off the old panel and replacing it is something I'm not comfortable with.
0 ·
The panels are trickier and more expensive. @Verna has a nice setup (https://tab-rv.vanillacommunity.com/discussion/12664/adding-a-second-solar-panel). I believe you could add a 200-watt panel to what you already have, but that would require a charger larger than a 75-15.
If your current system still works, there is nothing wrong with using more than one controller. In fact, it is best way to optimize panels with different specs. We do that with our 400 now.
Virginia Beach, VA
What I haven't been able to find is where the wires from the original panel go into the roof. I'll have to look closer, but if anyone knows where on the panel that connection is, it would be helpful.
The Sunflare panels are very high quality, roof service rated panels. That had a lot of value to me. My UniSolar panels on SUNT@B had a similar rating and were still performing as new after 12 years and 80k miles.
