I was filling water for a trip and something went wrong. I kept hearing creaking noises coming from the trailer. I assumed this was just the unit settling on the suspension from the increased weight. then the noise became louder and constant. I went in the trailer and found the floor bulged, I looked under the trailer and bottom was bulged. no water was leaking anywhere and the overflow never opened. I turned off the water hose and disconnected it and while I was looking at it trying to figure out what the heck was happening the overflow suddenly opened and water came pouring out. I opened up the outside shower and turned on the pump. I've only pumped about 1/3 of the water out and that's all I can pump out, it acted liked and sounded like it was dry. the frame that holds the tank is broken. I'm not convinced the frame broke during this episode because I never heard metal break.
the tank never ruptured, just bulged. I don't know how the water intake is connected, maybe I pulled away. Does anyone know? Even if I take it into a shop I've got to get the water out to travel down the road.
Has anyone replaced a fresh water tank or any of its framing or supports? I'm not sure if this is a repair I can make myself.
Is there a check valve that seized up on the overflow valve or did something crawl in there and make an obstruction?
sorry for the sideways pic. this is the top of the tank. looks like it was glued to the wood and was pulled away when the tank bulged.
plastic popped off from the bulge, I did pull it down some more to see what was going on. This is as far as the water will pump down, you can see the level in the white plastic.
2020 Tacoma TRD Off-Road
https://tab-rv.vanillacommunity.com/discussion/11129/dont-let-this-happen-to-you-blocked-fresh-water-tank-overflow-with-nautilus-system
It sounds like your pump lost prime. Try closing all the faucets, then try the pump. You may need to prime the pump by attaching a short hose to the Nautilus intake and fill it with water then blow into it will the pump is running.
I hope the repair is not too terrible. I'd contact NuCamp and get some information on how the tank is hung and hopefully you can tackle it yourself. Also I wonder if the tube the pump uses to pull water out remained in place and when the tank dropped the tube is now above the water line and simply not able to pump out the remainder of the water. What about just opening the tank drain valve? That should remove most of the water. Maybe elevate the door side of the trailer to get more water in the direction of the drain.
Please let us know what is involved in this repair and how it goes.
You post sparked my interest to check if I have comprehensive, which I do
Southern Maryland
"Just Enough"
Looking closer at your photos, it appears that the square channel subframe was relatively thin. I tend to agree with your suspicion that the subframe broke at an earlier point in time. The head of the carriage bolt depicted in your first photo appears to have only been supported from above by the trailer floor underlayment, which presumably significantly contributed to the tank support failure.
In re-reading your posts, I noticed that you mentioned that the top of the tank appeared to have been glued to the floor underlayment. What did you actually observe? Was there glue residue present, or did you observe other indications that glue had been applied between the tank and floor underlayment?
