Best Weight Distribution Hitch for T@B 400?
124»
  • Lashley005Lashley005 Member Posts: 1
    I bought the recurve r3 and attempted to install them on my Honda passport 23 to the tab 400.  The bars where too long and the setup did not seem to work.  They are being sent back to Amazon tomorrow
    I just went to harbour freight and bought their $28 anti sway bar.
    I towed the tab with my passport this weekend with no sway bar or weight distribution hitch.  It seemed ok but I kept it under 68mph.  Trailer and vehicle did not seem to have any sag in the middle however I was lightly loaded
    I have also learned since purchasing my passport, (specifically because I needed a vehicle to tow the tab) that it will need a transmission cooler to tow more than 3500lbs.  That's an extra expense I didn't consider
    I like Fastway E2 400 or 600 lb hitch.  The 600 will require modification to the Boondock platform if equipped with one.
    Odessa, Fl.
  • BlueespyBlueespy Member Posts: 259
    Had our t@b 400 bdl since 2019 with some very long trips (months) and prepping now for another four month one to AK.  Use a standard hitch, a one arm sway bar, and keep the tongue weight below the factory recommendation.
    2025 Haven 220
    2020 Ford F-150 XLT (V-8)
    Niceville, Florida
  • den1jenden1jen Member Posts: 41
    @Blueespy, not sure if you have left, maybe we will see y'all up there in AK this summer as we are heading out in soon for AK as well.
    2023 Tab 400 BD
    2023 Ram 1500 crew cab
  • 1DRR4061DRR406 Member Posts: 10
    No need to modify the platform on this 400.
    2022 T@B400 BD behind Toyota Highlander XSE
    This video referenced in 2019 above is very relevant as this post continues.
    Leaving early July.  You can't miss our t@b, it has flamingos on each side.  If you see us, please come say hi.  We always stop to say hi when we see fellow nucamp travelers.  Safe Travels
    2025 Haven 220
    Niceville, Florida
