Air8 Reprogram for Continuous Fan
2»
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,015
  • EasternJLEasternJL Member Posts: 106
    Thanks for that.  What I'm looking for the admin manual for settings that require the special password (8699).  There are numerous settings there that aren't accessible to normal users, but without some instructions, it's kind of a mine field.
  • stephengstepheng Member Posts: 112
    Has anyone figured out how to slow the fan down?  It’s still really loud at low speed. Is the fan motor speed digitally controlled or does it have multiple taps? Anyone thought about adding a PWM controller to slow it down?
    2022 T@B 320S Boondock
  • CharlieBCharlieB Member Posts: 11
    @EasternJL : I contacted Josh Elwell at Elwell Corp yesterday and asked him if he could send me a  list of the codes for the functions that can be accessed through the programming interface on the Air8. Here's his response:
    Hi Charlie,
    Attached is an image that has the other settings that are changeable in the air8 menu.
    We typically recommend not changing the other settings, but there are obvious use cases if you have something specific in mind.
    Thank you,
    Josh Elwell
    I will include the image he sent below.
    I also asked Josh if it was OK to share his response with this forum and he said "Absolutely! Feel free to share!"
    I hope this is helpful
    2021 T@B 320-S Boondock | 2019 4Runner | Knoxville, TN
