Hi. We are picking up our Tab on Friday. I was thinking to put lug nut covers on each wheel lug, but do not know what the size is. my order size options from Temu are 17mm, 19mm, 21mm.
You may want to check your lug nuts before you purchase lug nut covers. I just discovered today that on our TAB the lug nuts have covers on them. I would be surprised if not all TAB’s already have lug covers.
I replaced ours with solid (non-acorn) lugs. The new lugs are also compatible with those on our TV, so a single lug wrench (or socket in our case) works for both TV and Tab.
2023 Tab 320S
TV 2025 Telluride X Type
https://tab-rv.vanillacommunity.com/discussion/comment/7234#Comment_7234
I ordered these from E-trailer for my 2020 320S (non-boondock). Perfect.
