Has anyone reinforced the Yakima Roof Rack on a 320S? Perhaps via extending bolts through to the inside? Perhaps adding cross member beams inside? (The weight limitation appears to be because the rack is only attached to the camper via self-tapping screws that only penetrate one side of the internal aluminum cross-beam. Why not put bolts all the way through? And anchor them to a cross member(s) inside the main unit?) I'm not worried about aesthetics; looking to make the roof rack functional beyond it's 70lb capacity. Thanks for any guidance.
1 ·
The sidewalls are a stryfoam and plastic panel sandwich which isn’t designed for much weight, regardless of how things are attached to it. The walls have no hidden “studs”. After upgrading the rack—to-roof mounting, it’s unclear how much additional load it would take before the roof itself or walls start deforming.
My 2 bikes combined are less than 60 lbs. So not adding a huge amount of weight. Along with the spare and a couple of ancillary times (collapsed table, outdoor mat, even 2 gallons of fuel) - the total weight is still under 125lbs.
I think the Yakima rack was an 'after-thought' addition to the trailer. So it was mounted 'as best could' to the existing trailer design. Through-bolted on the bottom, but only 'screws into the exterior sheath up the sides and top. Therefore it has the very minimal recommended weight limit of only 70lbs. (NuCamp doesn't want to change the primary trailer frame construction to accommodate a beefier rack load capacity. (Though I bet it wouldn't be difficult or expensive to do so - and would be a real benefit to future sales to make that rack option more functional)
I'm confident that with the insights provided by you all here, modifications can be made that don't jeopardize the integrity of the trailer and I'll be able to improve the load capacity/usefulness of the rack. Thanks much.
St Catharines, ON
Another option is to buy a car/truck cargo box if your tow vehicle has side rails. We use it to keep our rug, side tent and chairs. It comes in handy if it rains and everything is wet when it’s time to leave.
Southern Maryland
