Lithium Battery…Ok to Leave in Camper Over Winter
I’m getting conflicting advice on whether or not to leave my Lithium batteries in our camper over winter or bring them inside to a warmer climate.
It can get down to single digit temps at times where I live but many are saying you can leave the lithium batteries in place and just make sure they don’t receive a charge.
Does anybody have any insight?
2021 400 BD
2020 Tacoma TRD Off-Road
  • AnOldURAnOldUR Member Posts: 1,496
    Depends on the battery manufacturer. Most of today's LiFePO4's have a BMS that will shut down charging below freezing. To that point, you can draw power from a lithium battery below freezing, but charging at those temperatures is what can damage the battery. You always have the option to turn the battery switch off and turn off solar charging in the app during storage.
  • HoriganHorigan Member Posts: 713
    Unless it will be at single digits for three to four months straight, you should be okay leaving them out, disconnected.  Several brief excursions to single digits is be okay.  That's how my winter will be and I'm leaving them in.
    From Google:
    • Less than 30 days: Store between -20°C and 60°C (-4°F and 140°F)
    • 30 to 90 days: Store between -10°C and 35°C (14°F and 95°F)
    • More than 90 days: Store between 15°C and 35°C (59°F and 95°F)
    Rich
    2019 T@b 400
    Bellingham WA
  • manyman297manyman297 Member Posts: 1,380
    Thanks for the info! Looks like I should be ok. My batteries don’t have a built in shutoff but I can just turn off solar charging and the battery disconnect. Glad to hear I won’t have to pull them out from under the bed.
    2021 400 BD
  • BillCBBillCB Member Posts: 39
    I have the same concern. I can apply the battery disconnect, but how do I turn off solar charging? Through the Victron app maybe - or a circuit breaker? (2024 T@B 400)
  • SLJSLJ Member Posts: 588
    I leave mine in. They have a built in low temp cut off. I also have the Victron battery monitor that cuts off the Victron solar controller and the Victron Smart Charger if they're left on. Redundant as I also put a disconnect switch on the batteries that cuts everything off. Never know when you might need it due to a weather emergency so it stays ready to use.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2023 Ford Maverick XLT
    The Finger Lakes of New York
  • pthomas745pthomas745 Moderator Posts: 4,094
    @Billcb On the "SmartSolar" part of the app, on the Settings page, there is a "Charger Enabled" toggle switch. Just toggle it "off".
  • bjn2bjn2 Member Posts: 102
    @BillCB I've seen warnings not to leave the Victron solar controller in the off mode for extended periods. I"ve seen recommendations to instead disconnect the solar panel connections to the controller long term, but if you cover the trailer, you won't get solar power anyway. I have a second Victron controller on my trailer for an external solar port, but there's no incoming power to it unless I connect a portable solar panel.
    It's best for battery life to store the lithium battery at 80% charge or a little less. I do cold weather camping and although my battery doesn't have a heater, it's inside and I can warm it up and charge it using shore power before heading out.
    Utah-based
    2023 T@B 320 S Boondock
    From Battle Born ...
    I'm surprised they suggest removing the positive cable as an option.  Typically you remove the negative cable to eliminate the risk of shorting your wrench on a ground.  Less likely on a trailer verses a car.
    Rich
    2019 T@b 400
    Bellingham WA
    @bjn2 What’s the reasoning for not using the on/off function on the MPTT? I was hoping I could just turn the charge off and not have to deal with physically disconnecting anything.
    2021 400 BD
    @manyman297 The reasoning is probably that the controller will be in a standby mode and still draw a small amount of power. In my opinion, not enough to be concerned about unless you're storing for years, not just over the winter.
    edited October 2024
    The thought of some owners with, lets say, very little skills at this sort of thing: taking out 4 lithium batteries and the complex heater wiring, solar controller issues, etc....is a nightmare for a simple 4 month over winter "storage".  And, then: having to put it all back.
    This is all seemingly overkill.
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 9,815
    Regarding requiring a disconnect of the panels from the controller:  If the “disable charging” function malfunctioned, charging and battery damage may occur.  So, physically disconnecting may also serve as a belt and suspenders approach.
  • marleecampsmarleecamps Member Posts: 161
    Timely discussion.  I replaced my stock AGM batteries with a single Lifetime 230 ah battery with built-in temp cutoff and will be taking my Tab 400 to storage next week.  I am in the metro area of Minnesota, with temps routinely below zero in January and February - and I will not have access to my camper while in storage.
    The product manual states that "a temperature between 50 and 95 degrees is ideal for long-term storage".  (And also that I should place it in a fireproof container.  ???)  So it seems that it's in my best interest to pull my battery and store it inside a heated structure like my basement
    Three questions for our experts here:
    (1) Does anyone disagree with my assumption I need to pull the battery?
    (2) How do I drain the battery down to 50% before doing so?
    (3) Since the battery is required for the electric brakes to operate, do I need to wait until I reach my storage facility to pull it - and then reinstall it before the 30-mile drive home?  This will really be inconvenient but guessing it's necessary.
    Thanks for any feedback and advice.
    --Marlee
    2021 Tab400 Boondock; TV 2015 Jeep Grand Cherokee; Minnesota
    "Long term storage" for LiTime means...what?  1 year?  5 years?  The problems with some of the advice we get from the manufacturers is: they are white coat lab technicians and not RV owners.
    What would their recommendations be for a 4 month storage period of an RV?
    Would you pull your battery in the summer because the temps were over 95 degrees?
    @pthomas745 - The manual doesn't define "long term storage."  My rig will be at the storage facility for six months.
    There certainly is conflicting information on line, but nearly all sources state that temps need to be above zero and battery discharged to 50%.
    I'm still trying to figure out how I can discharge my battery before removing, as I will be towing my camper to the dealer for a glycol flush, and then towing it to the storage facility another 45 minutes away.  So even if I successfully discharge the battery at home before doing so, it will undoubtedly charge to full while towing - or simply sitting in the sun.  Is there a way to discharge it after removal?
    Has anyone developed a good plan for handling lithium batteries during winter storage in a colder climate?
    --Marlee
    @marleecamps You actually might end up charging your TV battery inadvertently as voltage will travel to the lower of the two and lithiums tend to have a higher resting voltage. I’ve even had this happen with my old AGMs…I realized the camper battery was providing a charge to my TV after hours of towing.
    Yes, discharging these batteries is going to be an issue. I may just run the fridge and fan all day and see where that gets me.
    2021 400 BD
    Here’s an article from LiTime…a little confusing and contradictory:
    https://www.litime.com/blogs/blogs/how-do-you-store-lifepo4-batteries?srsltid=AfmBOorWs7MpIWu170mqHRIGqy2ZAyydXwZtdxwmWkccPTxvT932Mh7i
    Long term is defined as 90 days or more. Storage temps for that length of time shouldn’t fall below 59 degrees. They also recommend discharging to 50% at the max…so you probably don’t need to discharge it that much. I’ve heard 80% is fine. They suggest it’s good practice to check the voltage every 3 months in storage.
    Looks like I’ll be disconnecting and storing these inside my house after all (ugh).
    2021 400 BD
    @manyman297 - After some more googling, I came across the recommendation to use a lithium charger to discharge the battery once removed from the camper.  Guess I didn't realize they can be used to both charge and discharge batteries.  This makes a whole lot of practical sense, and I will be ordering one.
    Given our climate, I believe removing the battery after towing it to the storage place seems to be the wise move, based on what I have read to date.  And at least it only weighs 45 pounds - pulling those two 70-pound AGM's would have been problematic.  In hindsight, it's possible I should have been removing those during winter as well.
    --Marlee
    @manyman297 - good article.  Thanks!
    On the positive side, I was very happy with the performance of my new lithium battery this summer while boondocking.  Filtered sunlight was enough to recharge them to full every day.
    --Marlee
    Ours were great but I did notice that it took a while to charge them back up. What solar panel are you using? We have the stock 160w panel on our 2021 400.
    2021 400 BD
    Factory delivered solar setup - no mods.
    --Marlee
    Can someone please tell me how to disconnect the solar power on my 2024 T@B400? If I try to do it with the Victron app it tells me this should be done only briefly for maintenance purposes. Is there a connector somewhere? A circuit breaker?(I can't see one).
    If I simply disconnect the battery cables, what happens to the solar power being generated?
    As you can tell this all new to me! Any guidance appreciated.
    @BillCB tell us what battery setup you have.  What exact device is giving you this "message"?
    To turn off the solar controller, there is a "Charging Enabled" toggle switch.  You can just move the toggle to off.  That stops the solar controller from charging.  Disconnecting the battery cables will also prevent the batteries from charging from either solar or shore power.
    Thanks for responding!
    I have the standard factory supplied Lithium (one) battery and solar charger. Works very well, but of course it continues to charge the battery even the battery disconnect is off.
    Where is the Charging cable toggle switch?
    The message appears on the Victron app on my iPhone.
  • Bill&SuzeBill&Suze Member Posts: 99
    @pthomas745, @BillCB is correct in saying that the Victron SmartSolar app warns against toggling off the charging enabled switch. Mine does the same so I'm leery of going that route to stop solar charging. I have the same T@B and battery/solar charger setup as he. I will be covering the camper and expect the panels to stop PV production. Do you agree?
    Susan & Bill, Yarmouth, Maine
    2024 Kia EV9
    I will never understand Victron.  What exactly would be the issue of having the charger  off?  Reminding you that charging will stop is good....but for "maintenance purposes only?"
    Even the Victron Forums agree there is nothing inherently wrong with turning the charger off.
    Some owners report that their solar does work through the cover.  There are several grades and thicknesses of covers, and I suppose a "thinner" cover would let some sun through.  My PaHaQue cover seems too thick to allow any light through, though.
    Quick update. I ended up just pulling the batteries out for the winter. Ultimately it’s not a huge deal but just another thing I’ll have to do for winterizing. Peace of mind I guess.
    2021 400 BD
    @manyman297 - how did you disable the solar?
