Rainier Apex ST235/75R15 Trailer Tires Supplier
For anyone with the factory Boondock tires looking to replace with the same tire, I have located the official source:
Rainier Apex ST235/75R15 LRC Off-Road Radial Trailer Tire | Trailer. Set. Go! (trailersetgo.com)
Currently $194 each including UPS to you in USA. In addition you would need to have a local shop install them.
At least this is an official dealer and a source if you want to use the Boondock OEM tire.
  • BaylissBayliss Member Posts: 1,379
    Nice find, @N7SHG_Ham.  How did you locate the seller?
    @Bayliss I emailed Tredit who makes/wholesales the tires. They forwarded my info to the place I linked, which I understand is a sister company and the official sales arm to the public. This may be the only official outlet to end users, unclear about that. The good thing is they seem to be an official outlet and shipping to you is included for the price quoted. Not as convenient as going to a local tire outlet, but I suspect just a few days to get tires anyplace in USA.
    I have personally been happy with the Boondock tires and while there have been a few failures reported, overall they seem decent quality and I thought they had a six year warranty, but it might be four year, either way better than most tires.
    Another option to keep the "off road tread" and are rated highly are as follows.
    Falken Wildpeak
    235/75R/15
    Load Index 116 = 116 2756 Lbs.
    Load Range = E1
    Since previously there wasn't an option to buy replacement Rainier (I never spent much time searching but others did), I started to look at other tires commonly available. Currently these are $154.00 each at Discount Tire. https://www.discounttire.com/buy-tires/falken-wildpeak-a-t3w
    I am pleased with the Rainier as far as tread wear etc. So who knows what I will use when the time comes. I know some have put standard Goodyear trailer tires on in place of the Rainier and are happier with how the camper tracks (less wandering).
    Brad
    2020 400 BDL aka "Boonie"
    Concord, NC
    @Dutch061 the Fallen tire doesn't appear to me to be a ST tire? There are a few AT tires in the OEM size, Michelin Defender is another.
    From what I have found the Rainier Apex is the only ST tire in the original size and about the only "off-road" tire in any size for trailers. The GY Endurance is a slightly smaller tire in a highway tread.
    I've put about 20K miles on the Apex tires that came with my 2021 400 Boondock and they have performed great and still look perfect. I'd happily replace them with the same when the time comes. I've put tire pressure monitors on them, and they run cool too.
    I wonder if we could buy these from nuCamp directly as well?
    The specifications I took from the sidewall on my Rainier's are as follows.
    235/75R/15
    Load Index - 2340 Lbs
    Load Range = G
    So, nearly as I can tell the Faulken Wildpeak has around an additional 16% Load Index (2756 VS 2340). With that being  said, are they "ST Tires", no but they exceed the ratings of the OEM so I wouldn't be afraid to use them.
    As @ChrisFix said, the Rainier's are wearing well. Mine have around 12K on them and are wearing well. Since I am a long way from needing tires, who knows what I will do when the time comes.
    I am very fond of Discount Tire, they sell tires and nothing else. Plus free rotation and repair, even if they didn't sell you the tires. I have bought several sets from them, appreciate the fact they don't try to sell you everything under the sun like other tire stores.
    Brad
    Concord, NC
    Thanks for the response @N7SHG_Ham.  I have had a similar experience as that described by you and @ChrisFix.  The only issue I have encountered (which has nothing to do with the tires) is that I replaced the stock valves with high pressure valves, but those failed (slow leak in both tires and the spare, so maybe just not good valves to start with.)  Those were intalled by Big O Tires.  I replaced them with steel valves purchased at Les Schwab in California - - my preferred tire dealer, but they do not yet have any shops in Arizona.  I have not encountered any air leaks since I made that change.
    edited October 2021
    Good point Bayliss on the tire vale’s causing small air leaks.
    The Wildpeak tire’s are good off road, especially when aired down 25-30%, they track nicely and are used on a lot of Jeeps and off road trailers.
    Edit:  That said, they are not a good road trailer tire, as they are ST (small truck) tires and do not have a the same sidewall support as a trailer tire like the OEM Rainier tires that come with the TaB.
    Please folks, stop recommending non trailer(ST)for trailers unless trailer specifies this.  Trailer tires are designed different for trailer use.
    Odessa, Fl.
  • MuttonChopsMuttonChops Member Posts: 1,756
    In general ST tires have stiffer sidewalks and a flatter thread area.
    For many years ST tires in the T@B 235/75R15 size were not available or limited to 'highway' thread pattern.  NüCamp and it's suppliers factory installed non-ST tires.  A typical tire being the Milestar Patagonia A/T 235/75R15 XL.  XL tires have reinforced shoulders which is similar to the ST construction while providing the 'off-road' look.
    Considering how lightly loaded our tires are by a T@B compared to the tire maximum ratings I support the NüCamp choice to using XL tires.
    All that said;  now that a retail source has been identified for the Rainier ST 235/75R15 with an 'off-road' look . . . . I'll use the Rainier to replace my Milestar when the time comes.
    I was at Discount Tire today getting new winter tires on my car and asked if they installed 3rd party tires. That is a yes, at least at my local store, so that will be who I use if/when I have these delivered by UPS.
  • carpensecarpense Member Posts: 30
    Rainer Apex ST235/75R15 LRC Off-Road Radial Trailer Tire
    Update August 2024
    • Trailer Set Go: $267 per tire, shipping included = $534.00 for 2 tires
    • Tredit Tire & Wheel: $117.65 per tire plus $153.66 shipping = $388.96 for 2 tires
    We saved $145.04 purchasing from Tredit Tire & Wheel
    The Tredit representative explained that Trailer Set Go is a "sister" organization of Tredit. Hope this will save someone some money. :-)
    Sara Carpenter
    @carpense
    That's a very reasonable price for the tires. My original Apex tires on my 2021 T@B 400 lasted very well. I ultimately replaced them with Goodyear Endurance tires as they were just more widely available, but I had no issues with the Apex tires over 4 years and many towing miles.
    And the Apex tires look really good on the T@B!!
  • targtarg Member Posts: 86
    I don't want to hijack a thread, but I don't think this warrants a new thread just yet...
    I recently ran across a Kenda off road ST235/75R15 tire at etrailer.  As my OEM Apex tires were getting long in the tooth (timewise, not wearwise) and were difficult to find, I decided to try the Kendas.
    The only negative thing about them is that they are D range instead of the Apex's C range.  If inflated to max sidewall pressure, that would definitely make a rougher ride.  But, if they are run at a correct for the load pressure (please don't start a flame war for that comment), the ride should be just fine.
    So far, I've only been on a short trip with them so cannot make any kind of informed wear/ride recommendation yet.  Just tossing out another possibility for those wanting an offroad ST tire.
    The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice. | -REBEC OF GINAZ
    2019 T@B 320S BD Lite, Jeep TJUR, Jeep JT
  • SLJSLJ Member Posts: 590
    I bought my matching spare tire and wheel from Trailer Set Go but I see they no longer offer that tire/wheel combination package and they have to be purchased separately.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2023 Ford Maverick XLT
    The Finger Lakes of New York
  • ColleenD2ColleenD2 Member Posts: 515
    ChrisFix how are those endurance working out for you? Any regrets leaving the hearty tire behind?
