I’m getting conflicting advice on whether or not to leave my Lithium batteries in our camper over winter or bring them inside to a warmer climate.
It can get down to single digit temps at times where I live but many are saying you can leave the lithium batteries in place and just make sure they don’t receive a charge.
Does anybody have any insight?
From Google:
2020 Tacoma TRD Off-Road
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
It's best for battery life to store the lithium battery at 80% charge or a little less. I do cold weather camping and although my battery doesn't have a heater, it's inside and I can warm it up and charge it using shore power before heading out.
2023 T@B 320 S Boondock
The product manual states that "a temperature between 50 and 95 degrees is ideal for long-term storage". (And also that I should place it in a fireproof container. ???) So it seems that it's in my best interest to pull my battery and store it inside a heated structure like my basement
Three questions for our experts here:
(1) Does anyone disagree with my assumption I need to pull the battery?
(2) How do I drain the battery down to 50% before doing so?
(3) Since the battery is required for the electric brakes to operate, do I need to wait until I reach my storage facility to pull it - and then reinstall it before the 30-mile drive home? This will really be inconvenient but guessing it's necessary.
Thanks for any feedback and advice.
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota
There certainly is conflicting information on line, but nearly all sources state that temps need to be above zero and battery discharged to 50%.
I'm still trying to figure out how I can discharge my battery before removing, as I will be towing my camper to the dealer for a glycol flush, and then towing it to the storage facility another 45 minutes away. So even if I successfully discharge the battery at home before doing so, it will undoubtedly charge to full while towing - or simply sitting in the sun. Is there a way to discharge it after removal?
Has anyone developed a good plan for handling lithium batteries during winter storage in a colder climate?
https://www.litime.com/blogs/blogs/how-do-you-store-lifepo4-batteries?srsltid=AfmBOorWs7MpIWu170mqHRIGqy2ZAyydXwZtdxwmWkccPTxvT932Mh7i
Long term is defined as 90 days or more. Storage temps for that length of time shouldn’t fall below 59 degrees. They also recommend discharging to 50% at the max…so you probably don’t need to discharge it that much. I’ve heard 80% is fine. They suggest it’s good practice to check the voltage every 3 months in storage.
Given our climate, I believe removing the battery after towing it to the storage place seems to be the wise move, based on what I have read to date. And at least it only weighs 45 pounds - pulling those two 70-pound AGM's would have been problematic. In hindsight, it's possible I should have been removing those during winter as well.
On the positive side, I was very happy with the performance of my new lithium battery this summer while boondocking. Filtered sunlight was enough to recharge them to full every day.
If I simply disconnect the battery cables, what happens to the solar power being generated?
As you can tell this all new to me! Any guidance appreciated.
I have the standard factory supplied Lithium (one) battery and solar charger. Works very well, but of course it continues to charge the battery even the battery disconnect is off.
Where is the Charging cable toggle switch?
2024 Kia EV9
