Hello again! Still going strong with my 2014 T@B 320 S, one of the first units built with the Alde and integrated shower/toilet.
I have been through numerous attempts to improve the battery situation, especially since most of my camping is off-grid on Vancouver Island with limited solar for 1/2 the year.
1. I started with a nearly dead wet cell battery inherit from the previous owner. Disaster! First camping trip and all the alarms going off.
2. I tried a lithium battery but I had endless problems with it decharging, possibly due to not being compatible with my non-lithium converter.
3. I switched to a 12V AGM battery which was great but it was not charging while under tow. I later found out that the 7-pin plug only had 4-pin wiring. I kept returning to the shop that installed the hitch and they finally figured it out and that got fixed. I use a simple ANCEL Bluetooth battery monitor so I was able to prove the “no charging under tow” problem.
3A. The suitcase solar panel works great but it is of limited use off season under the dense forests at this latitude.
4. I got the conversion kit for 2 x 12V batteries but it didn’t fit on the existing battery tray of my older BAL trailer and would have required welding. So I abandoned that idea.
5. Now, I want more amp hours for my winter off-grid trips. I was limited to about 60ah with the single 12V AGM. I put a disconnect switch on the radio to further limit passive drain and the dreaded blue light. The Camco dual battery box just fits in front of the tub and I’m going to try that solution with 2 x 6V AGM battieries.
https://www.amazon.ca/gp/aw/d/B07V4482W1?psc=1&ref=ppx_pop_mob_b_asin_title I’m hoping to have more ah to work with using this configuration.
6. Also to mention, when my trailer is not in use, I shut down the breakers, pull a fuse and keep the battery on a simple trickle charger. Awkward but works great.
By far, the most $ I have spent on mods and repairs has been in the battery department. Cleaning out the Mason bees that plugged up my fridge exhaust ran a close second. I’m hoping the dual 6V AGMs will do the trick. Still loving my little T@B!
https://tab-rv.vanillacommunity.com/discussion/comment/208135#Comment_208135
You keep talking about your off-grid camping and the lack of solar generation. If this is the case, then LiFePo4 batteries are ideal for this type of situation. They would provide the most amount of usable amp hours.
As long as you are fully charged before heading out, a lithium battery would serve you well.
Ken / 2023 Tab 400 “La Bolita” (23,000+ miles) / 2024 Toyota Sequoia
2025 - 1 Trip - 16 nights - 2 National Parks
A nice shot of the mountains - Excuse me - but indeed, 180 degrees will place my T@B in a rain forest that we spent two nights and three days in. The Best solution would be two 12V Lithium batteries wired in parallel connected to a Lithium rated converter under the seat a seat in your T@B.
However, with my 3-way on gas and limiting DVD viewing to 1 a night, We only had a little sun while we visited an adjacent National Park, Our two 6V AGM batteries provided for us - though they were depleted at the conclusion of the third day when we left
2022 NuCamp T@B 320S Boondock
2023 Volkswagen ID.4 Pro S Plus AWD
Regarding fires, you may be confusing Lithium Ion batteries with LiFePo4 batteries.
Properly installing two LiFePo4 batteries in parallel is safe. Your comment makes it seem like 6v batteries wired in series are much better.
Thanks for the electrification. ROA off road sellsTrailers made in Australia are often wired that way and I know some good T@B dealers that offer multiple Lithium battery conversions. I guess like most things - a professional installation is best
I changed my '21 320S to two inside 100AH Lithiums. We pretty much only boondock. Only plugged in once this year (ADK Rally). After two years with the 105 watt panel on the roof and a portable 200 watt suitcase, the lowest my batteries have ever been powering the fridge 24/7, lights, pump, stereo, TV, etc. the last two years is once down to 45% and that was with over a week of rain and total overcast. I figure I have at least five days of power with absolutely no recharging. The Ford truck typically provides 7.5 amps when towing and 5.5 when idling so more than enough to run the 12 volt fridge and charge the batteries.
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
I agree - far less expensive - keep them on a trickle charger when the trailer is idle and they will last - It just depends on how long he wants to Boondock without recharging
