I own a 2015 320S Boondock. I brought my trailer into the garage to start fiddling. Yesterday, I plugged it into the house current, turned on the heat, and all good. Didn't get around to any fiddling, so I shut it down. This morning, I turn it on and nothing. No clicking, no anything... The analog thermostat is set on (2) lightning bolts, no propane, heat/hot water, and the dialer on 5. I shut everything down and pulled the plug with the battery off. I plugged back in and tried the Alde with no success. Checked the fuses, the breakers, the plug...nothing. I have attached some pictures in case I missed something to check. I would really appreciate any suggestions.
2015 Boondock
0 ·
Second, when you 'checked' the three fuses did you remove them and verify with an ohm-meter?
That is the only reliable method. Two Green Case on control board and One on DC Fuse panel
Third, house power service appears to still be OK (indicator at Alde 120VAC outlet)
Fourth, Now turn on Alde at Planel with:
One Electric Coil, No propane, Heat+water, and finally temperature in 3.5 - 3.75 range
Wait a bit - - - has Alde started to operate ?
TV 2025 Telluride X Type
You might try:
A] At this point we all have been assuming your 12-VDC is OK.
Alde requires for operation.
So maybe your battery died on the first day AND your convertor has failed.
Do Any of the 12-VDC items ( Fan, Cabin lights ) function correctly?
B] Completely power-off trailer. Battery Off (if no disconnect switch remove in-line fuse).
And shore power off.
Wait 5-10 minutes and power back up; battery on first.
C] Have you set the Adle Electric to Zero and Propane to On
To see if propane only (with battery on) works.
Calling @ChanW. Any insight?
