I got a quote from Nucamp to convert/replace my existing Wfco 8735p to a 48-00-3194 Converter - 35 amp with lithium switch (that’s the description on the quote).
The quote also includes installing a 48-00-3108 solar/inverters - solar port - female connector (also the description on the quote).
My lead acid marine battery is close to six years old, so I’d like to go the lithium route. Other than a lithium battery, what else do I need to take into consideration?
Am I correct in assuming shore power will fully (and ‘quickly’) charge a lithium battery?
And if I were to purchase a 100w solar panel, would I need other accessories?
In the past I’ve heard of charge controllers, smart shunts, etc but I don’t know how those relate here.
Comments appreciated. Thanks!
Suggest you ask nüCamp to clarify what their Part Number items include in detail.
Expect the change-over is pricey so you should have all the details.
For example on 3194 Convertor. Are they changing out the WFCO Power Center if so to what model or are they only changing the Convertor Board and again to which WFCO type. Also, ask them to clarify if "lithium switch" means an auto-select or a physical switch. If auto-select request nüCamp to install the WFCO Jumper that holds/forces an auto-detect convertor board into Lithium only mode.
For 3108 consider asking for full parts list and a wiring diagram. Could be the "3108" part number includes the extra items a typical installation would have.
1. You only need to upgrade the power converter, not the whole power center.
I should probably start by stating what my goal is: to find a cost effective, efficient method for utilizing a lithium battery in our 2018 Tab 320-CS that has a power center that does not support lithium batteries.
@pthomas745 last paragraph states: "Many owners have completely skipped the changing of the non lithium WFCO units in their trailers, and use their properly configured solar controllers to charge the lithium battery. There are many very simple lithium battery chargers that can attach permanently to the battery and allow them to be simply plugged into an electrical outlet to charge your lithium when needed."
This sounds like the solution I would like to pursue.
So lets say I have installed the Lithium battery with my existing power center and we are off-grid.
1) Would this power every device just like my lead acid battery? i suspect it would.
2) Would the tow vehicle with a 7-pin connection provide any charge while in tow? I suspect it would be very little (and slow) due to the power center not supporting lithium.
3) Would using a lithium charger such as the one suggested by @pthomas745 require the battery switch to be in the on position when be charged? (My current battery does require the switch to be in the on position but I assume that is because the 30 amp cord runs through the existing power center to get to the battery.) I suspect it would not since the power is connected directly to the lithium battery.
I think this solution would be a good starting point as it will introduce me to the lithium world and once I am comfortable with a lithium shore power solution, then we could move forward with an off-grid solar solution.
Does that make sense?
Thanks, Jerry
Three last questions (for now):
1) Were I to install a lithium battery and purchase a charger, how would I monitor the battery’s status? Would the existing lead acid battery monitor button (the one currently in our tab) work or would there be another method for monitoring the lithium battery such as an app installed on my phone?
2) And if we were plugged into shore power using the 30 amp power cord, is it possible to also use a solar panel connected directly to the battery simultaneously? My thought is to do so, I would need to turn the battery switch off, and let shore power run the tab, and let a solar panel just charge the battery? And if I forgot to turn off the battery switch would there be any consequences is having two charge sources (solar and shore power)? Or is the battery smart enough to detect and adapt to that situation?
3) Are the chargers waterproof or does the battery need to moved indoors to use the charger?
Thanks, Jerry
1. There are several ways to possibly monitor your battery: buy a lithium battery with a built in monitor and bluetooth connectivity to connect to an app on your phone; install a shunt that measures battery voltage and usage; use a multimeter to check the voltage. The nuCamp installed monitor is only good for lead acid batteries.
2) The 7-pin connector and its wiring deliver too low a voltage and current to charge a lithium battery. They won't even charge a lead acid battery. That has nothing to do with the power center's capabilities. You can install a DC-DC converter with separate wiring that can charge your trailer's battery while towing. I went with a Bluetti Charger 1, which wires with heavy gauge wire to the TV's battery. It has flexible output control, so I can use it to both charge my portable power stations and to charge my trailer's battery via a solar port I installed. My trailer has rooftop solar, but I wanted the ability to use portable solar panels. That lets us park in the shade and potentially use solar suitcases to harvest the sun nearby. Having the DC-DC capability means that we can use the tow vehicle to charge when it's cloudy.
3)I use a Victron Energy Blue Smart IP65 Smart Car Battery Charger,12V,15A to fully charge our 100AH lithium battery. We have a WFCO "autodetect" converter but it doesn't detect lithium batteries easily or retain that status. To have it work reliably, I'd have to remove the converter and send it back to WFCO for modification. You can get a quick disconnect connector with an inline fuse to quickly connect the Victron charger to your battery. That means you can use the charger for other vehicles when you're not using it to top off the lithium battery in your trailer. You plug the charger into an AC outlet while on shore power.
The simplest way to go lithium in your case is to replace your existing battery and use a separate smart charger. You'd immediately at least double your battery capacity with lithium of the same AH rating. From there, you could look at adding solar capability and/or DC-DC. I'd also recommend eventually getting a Smart Shunt that would give you a way to accurately monitor your battery's capacity and state of charge.
2023 T@B 320 S Boondock
2) You can charge your battery via a controlled solar source when the trailer is on shore power. You can have multiple sources of charge. Your converter won't provide high enough voltage to contribute past the 80% charge level. I have two solar charge sources, the WFCO converter, and the Victron charger and I can use them all simultaneously. It doesn't matter whether the power switch is on or off.
3) Many chargers are waterproof (the Victron I'm using is). Before I moved our battering inside the trailer for better cold weather performance, I would run the cord for the charger out the front window of the trailer - connected to the battery in the tub.
I have a 2013 CS-S and I installed a lithium battery way back in 2020 because I only camp with shore power a few times a year and I wanted to be able to run the 2way fridge.
3. Victron SmartSolar (solar controller) to provide power from solar panel to battery
4. SAE port on tub sidewall to plug in 160w portable solar panel
This arrangement has worked pretty well for me. I do run a little low on power during the winter when days are shorter, but I can usually make up for this by completely turning off fridge at night due to low ambient temperatures. Ambient temperatures over 95deg can also be a challenge as the compressor in the 2way fridge runs nearly continuously.
Thank you everyone for all your input. I really learned a lot in the last 24 hours.
Two other factors have come to my attention: We have the original fiberglass/plastic tub and the existing battery box is a for group 24 batteries. After eyeballing it this morning I'm not certain I can fit a group 27 box in there (to accommodate a larger battery. I was looking at the Renogy 12v 200Ah mini sized battery.) Also since it is is not a metal tub I don't think I can mount anything in that area without drilling into the diamond plate (which I am hesitant to do.) My only other thought is to relocate the battery to the interior but since my wife just made the bed, which we keep in place year round, I don't want to explore that option just yet.
Time to do more homework!
Thanks, Jerry
Lots of folks have converted the nuCamp Group-24 in older plastic front tub to a Group-27. The most common approach is to place an ~1-inch filler board in the Group-24 frame base then mount a Group-27 frame or box or frame and box on top of the original. Being sure the filler board is screwed to the trailer.
One example:
Forum Thread for above
Thanks, Jerry
I had a 3/4" sheet of plastic that I cut to the size of the base of the box and mounted to the frame. There are other options for this. The idea was to have something supporting the bottom of the box for more rigidity. There was enough slack in both the gas and electric connections to mount them inside the new truck box.
It's been constant change in the way we utilize the space. The second picture is from after the switch to dual batteries. It's a little different now, but it shows the gas regulator, cutoff switch and solar controller mounting.
