For the life of us we cannot get our 2021 320 CSS to backup straight.  With all wheels aligned straight the slightest reverse motion and the trailer wanders one way or the other, and steering corrections don't seem to help.  We tow it with a 2020 Honda Ridgeline.   Any suggestions, are extremely welcome.
                0 ·
John, Northern California
@Canyoneer, the suggestions by @TourDeForth are good for troubleshooting whether the brakes are the issue. If that is not it, I have attached some towing and backing tips I put together some time ago. I do not recall if I have posted them previously, but now is as good a time as any. I have added a few graphics that I found online to depict a couple of the key "backing" points.
In response to your specific question, take a look at the last few bullet points on that document. If you are fairly new to towing/backing a short trailer, you will find that backing in to a driveway or campsite can be significantly different than when backing a longer trailer. When I purchased my T@B 320 S, I downsized from a 30' 5th wheel. I quickly learned that unlike a larger/longer trailer, the T@B only requires very small turning movements when backing. Of course, a good "spotter" to help direct you is always helpful as well.
Also, if you do not currently use them, I highly recommend adding blind-spot mirrors to your tow vehicle's side mirrors (see the bottom of page 2.) Not only are they extremely helpful while towing, especially in heavy traffic, they make backing much easier, because they provide a larger viewing area of the sides and rear of your tow vehicle and trailer.
2017 F-150
Coeur d'Alene, Idaho
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota
