recommendation for cover T@B 320S
half
half Member Posts: 7
edited December 2022 in Products and Accessories
Just bought a 320 S and I am new to RVing. Can someone recommend a good cover?  Also a short list of essentials (other than a hitch lock and surge protector.  Thanks.
    Welcome to the forum!  I did a quick search and came up with lots of threads.
  • AnOldUR
    AnOldUR Member Posts: 1,755
    The first essential that pops into my head is some kind of interior fan for moving air to reduce condensation. Venting alone doesn't always do the job and the roof fan pumping out heat while drawing in cold can be a problem in really cold weather.
  • mgreen2
    mgreen2 Member Posts: 89
    this is what we bought - lifetime warranty
    Sold by: Amazon.com Services LLC
  • PNWtabber
    PNWtabber Member Posts: 492
    Everyone seems to have different experiences with covers, they are all susceptible to deterioration from UV exposure.  I just got a new Pahaque cover for mine, will see how long it lasts.
    You will likely need leveling and stabilizer blocks of some sort.  Lots of options out there.
    Enjoy your new trailer.
  • Slackers
    Slackers Member Posts: 490
    We had the $90 Classic Accessories and it lasted a couple years before disintegrating.  It fit great.  We replaced it with an East Harbor teardrop cover which fits big for $65.  It's currently out of stock on Amazon.
  • Basil48192
    Basil48192 Member Posts: 437
    We bought the Pahaque as well.  I just put in on for the third winter...and it still looks like new.  It fits well and (with a few extra bungee cords at the bottom) doesn't 'flap around' very much...even in a strong wind.
  • Dame_plume
    Dame_plume Member Posts: 75
    Welcome to you @half . I bought the AllPro adventures cover for the 320S.  Your essentials will depend on your camping habits.  Do you plan on boondocking a lot or go to campgrounds, for long or short trips?  I actually have two sets of must bring:  2-3 days or 5+ days plus.  I go mostly to campgrounds.  My favorites are my B.A.L. leveler and my Walker tent for longer stays.
    Sylvie and Mike, Ontario, Canada / 2020 Tab 320S (Charlie) / 2021 Chevrolet Colorado LT (V6) Enhanced Towing Package
    "The only place where you start at the top is when you dig a hole"
  • PNWtabber
    I purchased a new Pahaque cover last winter to replace the used one that came with my second-hand trailer.  I only recently got around to putting the new cover on my trailer, and the new one has 4 straps, rather than the 2 straps on the older version.  Seems very secure.
  • jbajor
    jbajor Member Posts: 233
    I purchased a cover from All Pro Adventures as they were the only company that had one specifically for my Ultimate Toys teardrop…. Super impressed with quality and workmanship. I suspect it will hold up a long time.
    Ultimate Toys Teardrop Camper
    Volvo XC-40
    SF Bay Area, California
  • jbajor
    +1 on BAL leveler! Also fresh water hose in case you need to refill and a grey/black water line if you need to dump when away.  Also spare fuses, particularly 15a automotive if you pop the 12v outlet fuse with too many accessories.
    Volvo XC-40
  • DukeHewett
    DukeHewett Member Posts: 45
    We've had both the Pahaque and the Classic PolyPro3 covers.   The Pahaque is definitely heavier and more expensive, BUT it fell apart after less than 5 years.
    The Classic lasted about a little over 2 years, BUT they have a 3 year guarantee.
    We sent them a copy of our receipt and pictures of the torn cover and they sent us a new one!   The Classic is easier to put on because it is lighter and more flexible than the Pahaque.  We will stay with the Classic covers because who knows if we'll keep the T@B 320 five more years and we could buy 3 Classic Covers for the price of one Pahaque.
  • half
    Thanks to you ALL.  Feel like a lot to learn.  @Dame_plume do you have specific separate lists that you are willing to share? My sense is that it will be shorter trips and, being a tent camper up until now I anticipate more boon docking.  Thanks.  So the BAL levelers raise the wheels independently for leveling apparently.
  • half
    Thanks @AnOldUR.  Have read some about small dehumidifiers but obviously that would only work with power connection.  Anyone have experience using the DampRid product?
  • BrianZ
    BrianZ Member Posts: 1,770
    We have used this for 5-1/2 years now..
    Classic Accessories Over Drive PolyPRO3 Deluxe Teardrop Trailer Cover, Fits 10' - 12', Tear-Resistant, Travel Trailer Storage Cover, Compatible with R-Pod Trailers, Clamshell Trailers, Grey/White
    https://a.co/2vEH7Wg
    It's starting to fray in spots & has a 3/4" hole in one spot, but still in decent shape.  Just to be sure we will have a replacement when needed, I recently bought another one.  We'll likely get at least 6 yrs out of it, though it only stays on during the off-season, mid-Nov through mid-Apr.
  • ChanW
    ChanW Member Posts: 3,165
    The fan for moving air is mainly for when you're camping, specifically in cool weather, as your body moisture condenses on the cool walls. Often just leaving a window cracked will remedy that. Otherwise air movement's a good idea, and some ceiling fans (ie: MaxxAir) provide for that without opening the vent. We've never tried just moving the air - Thanks @AnOldUR, will have to try it with our MaxxAir!
    As for the question of a dehumidifier, that's more something you would use in storage, and it likely will depend on your climate. When we were newbies, many people warned to use a dehumidifier, so I bought a few small, battery-operated ones. However, Western New York weather is dry in the winter, and I haven't had any need for the dehumidifiers! We'll warm up the Tab for a few days with the Alde to dry it out in the fall, and then crack the ceiling vent for the winter. Also, we always leave the windows and ceiling cracked when we're not camping.
    I could see a dehumidifier being more something needed for winter storage in the south or southeastern part of the country, where dampness might stay in your upholstery, etc.
    +1 for the Classic cover. We've used ours for four winters now, but figured it's cheap enough to replace every few years, if necessary.
  • PNWtabber
    I think it really depends on where you are.  I'm in the Seattle area, we generally have mild winters with a lot of moisture in the air.  I initially used Dri-Z-Air in my trailer (similar product to DampRid).  I didn't like having to keep an eye on the the water level in the reservoir and refilling the crystals/pellets.  That being said, it definitely pulled a lot of water out of the air and lots of people use these products when storing their trailers.  But don't expect to just leave it for the whole winter, as you may need to refill the crystals and empty water from the reservoir.
    Since I have my trailer at home and can keep it on shore power, I opted to purchase an electric dehumidifier.  It has a fan to circulate the air and just a little bit of heat.  We've had a few days this week where our temps were in the 20s (F) and my trailer stayed above freezing inside.
    My dehumidifier is by Caframo.  I bought it from Cabelas, but it is now available on Amazon.  It is designed to be used in boats and RVs.  DampRid and Dri-Z-Air are, I believe, designed to be used in closets, etc. in houses.
    https://www.caframobrands.com/9406caabx.html
  • webers3
    webers3 Member Posts: 436
    5th season in the North East
  • kenbac
    kenbac Member Posts: 7
    I have a 2020 T@B 320CS boondock trailer. I am wondering if anyone can tell me if the PaHa Que cover will work on my trailer. the spare tire is mounted forward of the utility box. https://www.campingworld.com/pahaque-wilderness-nucamp-t@b-320-trailer-cover-for-outback-and-boondock-140305.html
    ScottG Administrator Posts: 5,680
    It's interesting that the Camping World link shows different covers (with different part #s) for the Boondock vs "regular" 320. Exactly how they are different--or why the difference justifies a $20 price difference--is not at all clear given that the bodies on these campers are the same. Maybe the Boondock versions are cut a little more generously to accommodate the extra bolted on gee-gaw like the top mounted rack on non-CSS models?
    Regardless, the Paha-Que covers are a tight fit. If they haven't changed them since 2015 (when I got mine) I expect it will cover the utility box but not the front-mounted spare tire.
  • rfuss928
    rfuss928 Member Posts: 1,183
    This is a PaHaQue cover on our 2009 CS.  It would cover the front box and spare but was tight and inconvenient to access the front box.  Very well made and quite durable IMO.
  • jbajor
    Shout out for All Pro Adventures (https://allproadventures.com/).  They make an excellent product!!
    Volvo XC-40
