We are upgrading our Volvo V60 to a new Volvo XC90 to pull our 320 Boondock. On the V60 we used the Curt Echo wireless controller and hated it from day one. The brakes would grab almost every time we touched the brakes, even with the Max and Sensitivity dialed as far down as possible. After calls to Curt, our T@b dealer, and several Curt authorized dealers we gave up on it. So we are looking at a wired controller. Are there any controllers that look OK and are maintenance free? Does anyone have a wired controller on the Volvo? Thanks.
2021 T@b 320 S
0 ·
Autowbrake - Plug and Tow Trailer Mounted Electric Brake Controller
TV 2025 Telluride X Type
PNWtabber, why aren't you comfortable with the Echo?
I am hoping the trouble we've had with the Echo was related to the dopes as the dealership messing up the car wiring somehow and now that we're getting a new car, the Echo will work flawlessly. Hey, I can dream.
Boston Northshore
- I'm never 100% comfortable that I have the Echo unit securely seated into the plug and I'm always concerned it will "pop" out -- especially on a rough road. It just never feels as secure as I think it should and It is one of the things I check every time I stop.
- As you said it seems to be very sensitive and grabby--perhaps because the T@B 320 is so light? On our first trip with it, I got it adjusted so it stopped grabbing, and then when we left the campsite after 2 nights, it was grabbing again. I almost feel like I need to readjust the settings every time I hook it up, which isn't the way it is supposed to work.
- I often use my phone for navigation, so if I had to hit the "big red button" on the brake controller app, it wouldn't be the top thing on my screen--could be an issue in an emergency.
There isn't a lot of extra space in the XC60 cockpit and I couldn't figure where a brake controller would be mounted, but I am kind of wishing I had asked about it when I had the dealer do the hitch and wiring installation. The one good thing about the Echo is we can change tow vehicles easily.So far my XC60 is doing a fine job towing the T@B 320. When it is time to replace the XC60, I might upsize, perhaps to an XC90, just to be safe. We'll see.
Make sure you take a look at the Redarc brake controllers. They came out with a less expensive version last year, that would be my 1st choice. I use the more expensive elite, but it is a GREAT brake controller. Also takes up very little visible space on your dashboard.
https://www.etrailer.com/Trailer-Brake-Controller/Redarc/RED24FR.html
We have now put over 7,000 miles on it going cross-country to uCamp21 and zig-zagging on the way back West. It does everything that the P2 did, to include displaying troubleshooting codes on the emergency controller in the tow vehicle, when appropriate. Well, we haven't needed to do any troubleshooting, so other than "c" for connected or "nc" for not connected, it has been flawless. It has proportional braking based on your speed and other conditions and it's not grabby at all. I heard that there is a new version 2 with Bluetooth, but we got a good deal via U-Haul for an original version.
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
I would test that there is power to to your 12-pin (attach the trailer cable and see if the lights work), if that works, the Curt Echo unit should work unless there is a defect in the Echo. I don't know what your Volvo dealer is talking about. And, actually, a local trailer hitch place I have used previously would not install the wiring on my Volvo. Almost sounds like whoever did the wiring may have made a mistake? Sorry.
We had similar issues with the Curt Echo and have switched to the Prodigy RF wireless brake controller and we could not be happier.
It is a huge upgrade and has given us much more confidence in our brakes. We experienced many problems with the Echo including brakes locking up and activating randomly (!) and their tech support kept giving us a run around despite being within the warranty period. It was incredibly frustrating experience.
On the other hand, the prodigy rf is fairly straightforward to install (though you have to be comfortable drilling a few mounting holes into the trailer steel frame), and has worked flawlessly for us. Importantly, we also had excellent customer tech support when we needed it. Another point to mention is that you can use the prodigy rf on any tow vehicle since it's wireless.
Hope this helps.
I was a little hesitant at first to believe it was functioning properly because when we first got our trailer the fuse to the 7-way was blown and we would only get power to the Echo once the trailer was plugged in (the trailer battery was supplying the Echo with power). It seems to be working OK though. I think once we have more time, I will take the trailer in to get a Prodigy RF installed and ditch the troublesome Echo for good.
I've worked with electrical wiring my entire adult life and I'm 65 years old so that's a minute or two. I wired up my Redarc tow Pro Elite in my 2018 XC90 T6 Momentum with extraordinary care, using larger gauge wire than is necessary, using good solid high-end connectors and very careful tactics like disconnecting the ground leads on both batteries before touching the electrical to make a connections for my Redarc.
The set up worked fine initially but after about a month my electrical system went haywire kicking on the windshield wipers, making the dashboard light up like a Christmas tree and disabling the rotary on/off switch. I was able to resolve this issue by disconnecting the negative leads of both batteries starting with the rear one and letting it sit for half an hour before reconnecting the batteries starting with the front one.
I took the car to a trusted mechanic who said these Volvos are extraordinarily sensitive to aftermarket electronics being installed into the system. I then completely disconnected the Redarc and carefully reviewed my wiring plans to make sure it wasn't connecting to the battery + or chassis ground in an unfavorable manner or position. After a couple of weeks of planning I reinstalled the system and before I even got to the point of tapping into a brake light wire to signal to the controller when the brakes are being applied, I got the same craziness with the wipers automatically going on the dashboard lighting up like a Christmas tree. And this was just from attaching to the battery positive and to an official Volvo ground terminal next to the battery.
I have given up on hard wiring anything in this car and I'm now in the market for a completely autonomous trailer brake controller that requires zero modifications at the vehicle level.
The Volvo series vehicles I mentioned above that have factory avaialble tow capabilities utilize a trailer module that connects through a generic harness to trailer connector but, maddeningly, This module does not have a wire that goes hot when the brakes are applied! What that means is any trailer brake module you get that requires a brakes-on signal from the tow vehicle will require you to tap into or alter wiring on your very sensitive Volvo.
As I understand it, the Autowbrake requires this brakes-on signal so it will require you to tap into or modify your Volvo wiring to provide that signal, which is a very risky proposition unless you know exactly where and how to do this and trust me I spent a lot of time trying to learn that and came up empty-handed.
It turns out that the power that is provided to the rear LED tail lights does more than just turn on and off When the brakes are applied. There are sensors there used to tell the system if your brake lights have failed and notify you. That sensitive system can be a real issue if you don't know exactly what you're doing And how to do it.
From where I sit now, it looks like the Prodigy RF is the only system that will work with a Volvo of this class without requiring vehicle modifications. I was thinking of using the Curt Echo, but was turned off by the number of people who have difficulties with it.
I'll be going with the Prodigy RF and hoping and praying that this works because I probably spent an excess of 40 hours either researching this vehicle, ways to wire it, and doing the process twice now and my frustration level is to the point that I'm giving up on it.
2022 NuCamp T@B 320S Boondock
2023 Volkswagen ID.4 Pro S Plus AWD
2024 Kia EV9
My number one reason for going with it is that it is 100% independent of any electrical systems on the tow vehicle. Hardwired controllers are out of the question for me based on my experience with the Volvo so I'll keep my fingers crossed at the Prodigy RF does me good!
Volvo XC-40
SF Bay Area, California
What it doesn't require - which the Volvo doesn't output - is a dedicated "brakes on" signal.
