2015 CSS: Our freshwater tank only empties 20%. The tank is clearly 80% full. The pump has been confirmed as working fine. As the valve is at the front of the tank (design flaw?), has anyone tried installing a valve at the rear?
A group of competent RV problem solvers concurred with the above analysis. This problem must have been addressed by someone previously.
0 ·
Volvo XC-40
SF Bay Area, California
Good idea @rfuss928!
@Miwok - is there a vent tube next to your fill spout? If you leave the fill cap off, can you drain the tank?
