Brake Controller Recommendations
I have a 2015 Outback and just purchased a 2026 Santa Fe with turbo with plenty of towing capacity. Any recommendations for a wired or wireless controller would be greatly appreciated.
2015 Boondock
I've been using a variety of brake controllers over the years, from ancient Tekonsha voyagers to now a Redarc TowPro Liberty. The Redarc is great for modern vehicles which don't really have space for an under dash mounted device. In my Gladiator the unit is mounted under the steering column and the control knob fits next to the 12V outlet.Redarc also recently announced a wireless TowPro Link which looks pretty good but it's not available in the US yet.0
Thank you GG. I have received a recommendation from the installer to go wireless. When I know the model...I will share it next Tuesday.2015 Boondock0
Probably the Curt Echo, requires no work, maximum profit. From what I gather the current generation Santa Fe has an available towing package with all the wiring for a brake controller (https://hyundaishop.com/shop-by-model/2024-2026-hyundai-santa-fe-towing-kit/) I know some Asian manufacturers don't build vehicles with tow packages and leave it to their dealers to install one. Did you get your Santa Fe with the tow package from the dealer ?0
I’ve heard the Curtis Echo has had bad reviews. I’m using a wired Tekonsha Primus IQ in my 2012 4Runner. Just need the right wiring harness for an Outback.0
@michaelroyy, I have used the Autowbrake Electric Brake Controller for 5 years with 3 different tow vehicles and have to say I love it.2020 TAB 320 U
TV 2025 Telluride X Type0 -
FWIW I've been happy with the Prodigy P2 wired controller. Whatever you get, I strongly suggest you go for a proportional controller and not a timed controller.2024 320 CS-S | Ontario, Canada0
michaelroyy said:I have a 2015 Outback and just purchased a 2026 Santa Fe with turbo with plenty of towing capacity. Any recommendations for a wired or wireless controller would be greatly appreciated.Everyone but me appears to be enamored of wireless brake controllers. They certainly are easier to install than wired brake controllers, but they're also subject to RF interference and with a bazillion Bluetooth devices in my trailer I decided to go wired. I designed RF hardware for a living so I've seen how the sausage is made... The wireless controllers also stick WAY out of the 7-pin connector on the tow vehicle which is a problem on my VWs because the 7-pin connector faces down. A lengthy wireless controller would greatly reduce my ground clearance.I use a Curt Triflex NEXT wired brake controller. Curt makes vehicle-specific adapter cables for for both of my cars, so once I located the OEM brake controller connector under the dash (which was definitely an adventure), it was easy to plug in the adapter cable to the car and brake controller. It seems to work great on both cars.It looks like Curt makes an adapter harness for the Santa Fe. That makes it a plug-and-play situation in my experience.
2022 NuCamp T@B 320S Boondock
2023 Volkswagen ID.4 Pro S Plus AWD1 -
I’ll chime in here. Our first brake controller was the prodigy RF. We were novices to towing a trailer and we wanted to avoid drilling into our dash. It worked great for seven or eight seasons. But we were traveling out west on the Navajo reservations and it failed. The lesson learned is that you cannot easily replace these things on the road. We ended up installing the prodigy P3, which was plug N play. Had we known we would’ve installed the P3 from the beginning.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Happy Thanksgiving to you all. I appreciate the forum soooo much! I will try to answer as many of your questions as possible. I just purchased a 2026 Hyundai Santa Fe turbo to pull my 2015 320 Boondock. I ended up getting a Curt Echo Mobile brake controller. My installer, who I used 5-years ago for my wired Reliance, recommended it. The only thing he does is install hitches and controllers. He uses this controller himself. He also has set-up lots of them and has not had an issue come back to him. I did not use Hyundai because they wanted $2,000 out the door. I paid my person $900 for everything, parts & labor. He did use the Hyundai harness/plug. We hitched it up at his shop and it worked. The controller does stick out about 8", but it is not an issue for my car. There is a strap that helps lock it into place along with the lip that comes down from the plug cover. It should be very secure driving even on rough terrain. If at some point I have issues, I will repost.2015 Boondock0
We've used an Echo for 6 years. The few issues we have seen our fault. Take your time. Do the steps in order. The Echo works fine. About 9 months ago the app was updated. It is easier and more forgiving now. That being said, we just ordered a Redarc controller.... The Echo allows a brake controller for vehicles without a wired plug. Our current tow vehicle has a plug. This will free my phone to do other things.
As stated above, the more Bluetooth devices are playing the more interference there is. Heavily tinted windows, particularly the expensive tint with powered metal, will reduce the signal strength. This is true of all Bluetooth brake controllers.2018 320CS-S
"Just Enough"1 -
We have been using an Echo for 3 years with very good results. We had some BT connection issues when there was a weak battery in the trailer but that was easily resolved. The Echo controller continues to operate in the current settings even if the connection is lost.
You can free up your primary phone by loading the Echo app on an old phone (using wifi) and use it as a dedicated controller, I also put the Victron apps, BVM app and a Govee app on this old phone and basically leave it with the trailer. Doing this, your primary phone remains available for communications and all those other chores while on the road.
I used the Curt Echo previously, but now use the Redarc TowPro Liberty. The Curt does require a phone with bluetooth to change settings and manually activate trailer brakes, but it will function without one once it is configured, but I wouldn't recommend it. It worked for me but it did interfere with my tire pressure monitoring system and would cause my low tire light to come on and sometimes flash (it was alarming the first time that happened!) I finally switched to the Redarc when I got a new tow vehicle. The only other thing I didn't like about the Curt is that putting on the hazard lights (flashers) would cause the trailer brakes to pulse since the Curt interprets the tail light voltage and uses that to determine if you are apply the brakes or not.Something else that is interesting, and I'm not exactly sure how it works, but apparently brake controllers orient themselves to which way is up and motion detection. You will often see remarks about the controller learning and calibrating itself. Of course, I could be totally making this up, but I swear I read that somewhere??2025 Tab 320 S BD2024 Nissan Frontier0
I’m in my 5th year with a Teckonsh Primus - no issues. My current TV is a 2025 Santa Fe XRT. There is a plug under the left side of the steering column that fits the plug that comes with the Santa Fe hitch. A bit difficult to find and access.400 - 2019
St Catharines, ON0 -
Lots of good options listed above. I have used Redarc for the past 5 years and highly recommend it to anyone who is looking. It's performance is absolutely perfect, but the highlight for me is the install is the neatest on the market. No box hanging at your knees and looks factory installed. Also, they have great customer service before and after the sale.
2025 Honda Ridgeline Black Edition with Redarc Trailer Brake Controller1 -
Agreed. I just installed a Redarc in our new Highlander this past week.
Rich2019 T@b 400
That’s the cleanest aftermarket install I’ve ever seen! Slick! I wish they had a solution for my 2014 Touareg!Horigan said:Agreed. I just installed a Redarc in our new Highlander this past week.Adventure Cats living in the Pacific NW USA
2023 Volkswagen ID.4 Pro S Plus AWD0 -
Redarc has a variety of inserts. The one I used is universal. Just drill two 1/8" holes a half inch apart, then re-drill the lower hole to 1".
https://www.redarcelectronics.com/us/trailer-brakes/switch-inserts
Rich2019 T@b 400
The Redarc has a black box you fasten under/behind dash. This manual rheostat button plugs into it with small wire.
Caution to Tacoma owners:
A number of 3rd generation Tacomas (2016 to 2023) have experienced bizarre failures of this one brand in very cold weather only. Your third brake light starts strobing faintly at night, not visible in day.
Internal to black box there must be a Reed switch or diode that hates bitter cold in single digits F. Stops when warmer.
Documented by owners on Tacoma World forum.
I replaced unit last spring. If I have to do so again. Will go with another brand.
No issue on older 2cd Gen truck.
2021 T@B 320S Boondock/ 2012 Tacoma 4 cylinder truck / 2023 Tacoma 6 cyl. truck0 -
You’re referring to the so-called “high mount” brake light on the truck, not something on the trailer?Maxcamp said:Caution to Tacoma owners:
Documented by owners on Tacoma World forum.The Curt Triflex Next brake controller I use flashes both tail lights on my 2022 330S very briefly and dimly every few minutes. It’s only visible at night. I don’t think it would be visible at all if the tail lights were incandescent instead of LED. I theorize that the brake controller is running a continuity test to see if the trailer is still connected but I don’t know that for certain.Adventure Cats living in the Pacific NW USA
Unfortunately, VW doesn’t have switch inserts like most cars do. I’d have to use the surface mount control and drill holes in the dash.Horigan said:Redarc has a variety of inserts. The one I used is universal. Just drill two 1/8" holes a half inch apart, then re-drill the lower holeAdventure Cats living in the Pacific NW USA
Sounds like you’d need to drill holes anyway to mount the controller at a driver-accessible location.Rich2019 T@b 400
When I installed a Redarc in my Toyota Tacoma all my switch positions were occupied, I didn’t want to drill a hole in my dashboard because of the expensive repair if I decided to remove it. I considered installing the switch into the driver side A pillar. It’s not expensive to replace if I needed to remove it. Then I began looking at other panels on the dash and the cost replace the panels. I settled on the switch panel beneath the AC control panel.2023 T@B 320s Boondock, 2013 Toyota Tacoma TRD 4x4 2016 Toyota Tundra 1794 4x4
John, Northern California0 -
Purchased a Tekonsha 90250 Prodigy RF Electronic Brake Control to use with our 2020 Jeep Grand Cherokee and our 2019 t@b 400. System worked great - usually laid the brake controller on the center console within easy reach should I ever have to apply the trailer brakes separate from our tow vehicle. I still have it though we've upgraded our tow vehicle to a F150 which has a factory installed brake controller.
Haven 220
2026 Ford F150 Tremor 5.0
Niceville, Florida
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
