Replacing the kitchen HepvO drain pipe with Clear Removable Bottle P-Trap (T@B 400)
jimcenname
jimcenname Member Posts: 346
About once a year I remove the HepvO kitchen sink drain pipe trap to clean the sludge that accumulates. I am thrifty with water so the drain doesn't get flushed out and sludge collects. Each time I reinstalled the HepvO I fight drain pipe leaks for a day or two. This time I replaced it with something I found on Amazon. Installation was easy and no leaks so far. I like that I can see what collects in the trap. I can remove the clear part of the trap without disassembling or removing the whole p-trap. The clear bowl unscrews.
New trap installed, (updated to a working link) Amazon https://a.co/d/dVuO4J8  FYI The corrugated drain pipe is part of a prior repair to mate with a cut-off original drain line.
New trap assembled prior to installation. FYI The corrugated drain pipe is part of a prior repair to mate with a cut-off original drain line.
Old original trap assembled after removal. FYI The corrugated drain pipe is part of a prior repair to mate with a cut-off original drain line.
2019 T@B400
Southern California
Full-timer since 2019
  • dlb
    dlb Member Posts: 174
    I like the idea.  The link takes me to blood pressure devices.
    2021 Tab 400 Boondock
    2020 Audi SQ5
  • jimcenname
    Thank you for the feedback on the Amazon link. I fixed it and here it is too https://a.co/d/dVuO4J8
    2019 T@B400
    Southern California
    pthomas745 Administrator, Moderator Posts: 4,605
    edited December 2025
    This is really nice, and makes the install of a space saving trap like this much simpler. If you have a 320, the plumbing is a bit different, as there is a vent that goes up from where Jim's corrugated pipe run goes, so there may need to be a slight mod, there, but not very much.  This is Dale Helman's original post on a Hepvo install from 2018 which shows what I mean. (I'm sure there is a corrugated T-fitting out there somewhere.)
    It seems to me (with only a bit of examination) that Jim's mod in this post saves even more space.
    Many more examples of Hepvo and sink installs at these Forum links.
    ScottG Administrator Posts: 5,675
    I like that trap. My 2015 has a standard p-trap. I remember when Dale first wrote the Hepvo and it became popular DIY mod to gain a little more space under the cabinet. Eventually nuCamp started making Hepvos standard equipment on new builds. Coming full circle now, I guess...  :-)
    Reminiscing concluded (for now).
  • Horigan
    Horigan Member Posts: 890
    Looks great.  If you were getting gunk, I'd replace the corrugated pipe with smooth pipe.
    Rich
    2019 T@b 400
    Bellingham WA
  • AnOldUR
    AnOldUR Member Posts: 1,749
    I didn't like the P-trap hanging down and taking up space below the sink, but I had the same concerns with using a HepvO valve that you mentioned. My solution was to swing the P-trap to the back of the cabinet where it didn't interfere with the storage basket slide I'd installed. If I had seen your solution first, I would have gone with it. Still might.  =)
    MuttonChops Member Posts: 2,009
    @jimcenname Thanks for sharing. Looks like a simple and easy monitor/clean space saver.
    I currently have the nüCamp original sink P-Trap with no plans to replace . . .
    Expect I'm one of few that use the deep P-Trap as a cabinet contents separator
