Replacing the kitchen HepvO drain pipe with Clear Removable Bottle P-Trap (T@B 400)
jimcenname
jimcenname Member Posts: 346
About once a year I remove the HepvO kitchen sink drain pipe trap to clean the sludge that accumulates. I am thrifty with water so the drain doesn't get flushed out and sludge collects. Each time I reinstalled the HepvO I fight drain pipe leaks for a day or two. This time I replaced it with something I found on Amazon. Installation was easy and no leaks so far. I like that I can see what collects in the trap. I can remove the clear part of the trap without disassembling or removing the whole p-trap. The clear bowl unscrews.
New trap installed, (updated to a working link) Amazon https://a.co/d/dVuO4J8  FYI The corrugated drain pipe is part of a prior repair to mate with a cut-off original drain line.
New trap assembled prior to installation. FYI The corrugated drain pipe is part of a prior repair to mate with a cut-off original drain line.
Old original trap assembled after removal. FYI The corrugated drain pipe is part of a prior repair to mate with a cut-off original drain line.
2019 T@B400
Southern California
Full-timer since 2019
