Lot of info on this board and I am a bit mixed with issues that impact other years. Appreciate the thoughts.
I bought a used 2024 Tab 400 Boondcock this month. Was assured all is working 100% but have determined now the solar is not working. This model has the convenience package with the 100ah Battle Born and what I assume is the SunFlare Flex 310 W panel. Running MPPT100/30 Victron.
I have removed all service panels under bed and inspected fuses and wiring. I unhooked the solar panel leads into the Victron MPPT controller. I have zero voltage out of the SunFlare panel. I removed the inline fuse and test the wires behind the fuse holder what should be directly into the solar panel and still zero volts. There is no visible burns or defects on the solar panel on the roof.
I then hooked up a suit case 100W solar panel directly to the Victron MPPT controller and instantly get 60W and now the battery is charging. I obviously get voltage directly out of that panel on a similar test as I tried with the SunFlare.
In the app there is no history of solar charging (something I should have tested before buying but did not). I am now getting data on the history chart and actually adding to the battery capacity.
Does anyone know where the solar panel wire on this model comes into the roof of the camper? Do I need to remove the fridge to get to it as maybe there is an issue at the point of the attachment to the solar panel or do I likely just have to replace the entire panel? Is that a job recommended for the dealer or do it yourself?
So with all the background. I have bought this camper 2nd hand. I read the panels are 25 year warranty (I think), does that apply to 2nd owner? I assume I get no support from Nucamp due to its now under 2nd owner and more than 1 year old?
Any comments welcome.
0 ·
2024 Kia EV9
2022 Nissan Pathfinder
Cary, North Carolina
2022 - 11 trips - 34 nights
2023 - 4 trips - 21 nights
2024 - 5 trips - 51 nights
2025 - 5 trips - 18 nights
2024 Ford Ranger Raptor (10.5 mpg towing avg)
2018 BMW X5 xDrive35diesel (15.6 mpg towing avg)
2020 Toyota Tacoma TRD Off Road (11.1 mpg towing avg)
Just an FYI , we got an estimate to add an additional 310w panel to the front of our 400 (black canyon option ) , and the NuCamp quote was approx $2k . We decided to forgo the additional 310 panel on the 400 and just get a portable 400w panel that will work on both our 400 , and our Ford Transit camper van when needed.
2024 NuCamp T@B 400 BD, Charcoal / White
Our new 310W is still working well, but hearing reports like this has me concerned about the recent addition of one of these panels. Please follow up with what nuCamp service finds the problem to be.
Wisconsin and Florida
2023 Tab 320S BD
Just emailed nuCamp with the serial number from my 310W panel. Will report back when a reply is received.
I have been on the fence about adding the second 310w solar panel (Black Canyon) as I can really use the 620w of solar since adding 900ah of Lithium batteries .
While my unit is still at NuCamp , they did e-mail me (about 2 weeks ago) and confirm that they did have some new panels come in , and if I wanted them to install the second panel .
After a generous discount on the panel , parts and labor (NuCamp customer goodwill / customer service for having to bring our 400 back to the factory for warranty work, that only NuCamp could do ) , we decided to have them install panel #2 . We are approx 5-6 hours from NuCamp each way , so I figured it was either now or never to have the factory install the panel . Not even attempting that panel install myself ! Its all about the wiring run through the existing ceiling that I was basing my decision to not install myself . Hope it was worth it .
Due to pick-up our 400 this week sometime, so will let you all know how it goes !
I am a little relieved to hear that the panels themselves have a 10 year warranty . That is HUGE !
2024 Kia EV9
Since it's been reported here that nuCamp did not record the panel serial numbers in the past and that the label containing that number can not be seen after the panel is installed, did nuCamp tell you how they verified that your panel was not from the bad batch?
2023 Tab 320S BD
I am assuming they tested it to be ok . If there was any question , I would hope they would have replaced it since they had the panels on hand now, and they were already installing an additional panel on my 400 . I have faith in NuCamp, that they are confident the existing panel was ok .
2023 Tab 320S BD
We just had NuCamp install a 2nd 310w panel on our 400 while it was in for warranty work . I had been talking with NuCamp about having one installed and been on the fence , but while my 400 was at the factory , they told me they had a bunch come in, and asked if I wanted to have it installed.
I did notice that our original (2024) 310w panel and the new 310w panel do appear to be a little different construction . Both exactly the same size , but something is different about how the solar cells look .
For anyone interested , here is a picture of the 310w panel specs NuCamp sent me (not my panel , but prob from a warranty replacement panel as it appears to be melted a bit)
Comparing to the sticker on our 310W Sunflare, there is a slight difference in size and weight. Another difference is that the label you posted says MADE IN VIETNAM, but mine has no manufacturing location.
Also, I'd be interested in knowing more about, "something is different about how the solar cells look".
The size difference is probably just from rounding the numbers off, but not sure about the weight ...
