2021 400 BD
does anyone know if the window tension bars are what actually keep the windows in place? The little clip broke off on ours and I’m trying to figure out if that is why the whole front window just fell out or if the two were unrelated? I’ve reseated the window in the groove above it and it’s unclear if that’s all it takes
Your looking for visible damage on the ends or a gap of more than 6mm.
@RayJim the problem I'm having is there's no visible damage and the measurement shows no more of a gap.
Thanks
2017 T@B 320 Max S
2014 Ford Escape 2.0 EcoBoost
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
We called and spoke to an engineer at the distributor and they sent us a video showing one being taken out but it gives you some idea what to do. You have to remove the set screw and slide the track out and to the right then mount the window in the track and sliiiiiide it back in. VERY hard to line it up to get it in place, even with two people. Thankfully we have a Boondock model so that gave us a platform to stand on.
I am proud of myself for solving this from the starting problem to finish, that’s for sure! This window is working better than either of our other two. Dana at Missouri teardrop replaced ours a few years ago. The left piston never worked though so the window was held up with the right only.
