Hi Peeps,
I have a 2017 T@B. Even though things on this trailer are starting to fail, I love this trailer as its the perfect size for me.
- The dreaded 3 way refrigerator is very persnickety. Got that taken care of and now I keep fuses on hand at all times when I go camping.
- The shower pan cracked. Currently being held together with Flex Glue and Flex Tape, which I highly recommend.
- This last summer, the external shower sprayer blew apart inside the trailer where the Alde was located. Thankfully the Alde was not damaged.
- A couple of months ago, I went into the T@B to retrieve a sleeping bag, and found a puddle of antifreeze in the middle of floor. Found the hose that was worn with a hole in it. Fixed that and checked the other hoses as well as refilled the reservoir.
- The AC unit works but there is no place for the condensation to drain. Haven't quite figured out how to address that. However, since I rarely use the AC, that's a problem for another time, but suggestions are welcomed.
- We winterize regularly.
The purpose of this inquiry is to find out what else should I inspect and try to get ahead of on the maintenance side of things. All suggestions welcomed including buying a new trailer. lol
Thank you.
Ann
1. What model do you have? My overall concern is checking all the sealing and caulking on the exterior and along wheel wells where water can intrude, causing slow but significant damage.
2. Your Antifreeze Alde leak speak to potential corrosion along all the connectors. Best check them all by disassembly and then flush and refill system with fresh glycol to restore anti corrosion in the fluid.
4. Determine the health of your battery. Better options are now more affordable.
Others with more experience can add to this or make corrections
Good luck
QH
2020 400 solo
I just went through these three line items as we are heading out and I had let these maintenance items go for long enough.
Here are a few links if that helps.
https://tab-rv.vanillacommunity.com/discussion/comment/176110#Comment_176110
https://tab-rv.vanillacommunity.com/discussion/comment/34360#Comment_34360
https://tab-rv.vanillacommunity.com/discussion/4865/time-for-new-tires-usa-made-tires-now-available
next up-battery replacement.
2021 Ford F150 2.7 turbo
Trips - 48 Mileage - 63,452
