Replacing "Board" on Alde 3010 - Solved
The people at Blue Compass informed me that I need a new board to repair my Alde 3010 but that those boards are no longer available because my T@b is "so" old—2015. To me, 11 years does not seem that old, though I confess I drove a 1929 Model A to high school in the early seventies. Are the boards available somewhere—new or used? Can the average person do it themselves?
Alde replaced the 3010 with the 3020 a couple of years later so it's not really the age of the trailer. In any case have a look at this, you might not need a new PCB:
Have you contacted Truma in Elkhart, Indiana?
They have a website with an email option to contact them:
or by telephone at 1-855-558-7862, Ext. 1
The differences in the boards are probably fairly minor. Skip "blue compass" and talk to Alde directly, or ask someone like Missouri Teardrops to get you a straight answer.
Towed by 2014 Touareg TDi2 -
I just did a "Failed Circuit board" repair. It was the thermal fuse. The first thing is to confirm the (replaceable) fuses are good and then check the thermal fuse. do this by putting a temporary jumper from one side of the thermal fuse to the other. an Alligator clip jumper works great just so you can allow the 12v to get from one side of the fuse to the other. If you install the jumper and the unit fires up, you found your culprit. As this fuse is a safety device, remember jumpering is only a troubleshooting step, not a permanent solution. (in the below photo, The jumper is the white wire loop with the 2 light blue mark-up lines coming off it) To further my repair, I actually mounted Circuit board mount style screw terminals in the place where the old fuse was, and connected the thermal fuse to the screw terminals. I did this for 2 reasons. Soldering a thermal fuse is hard….the heat from the soldering iron can ruin the fuse, and like some had said, if I'm camping, not likely to have a soldering iron in my tool kit (I do carry the alligator jumper though) in the future, as others have stated, make sure the ALDE is not getting power hits as the camper is plugged in to the Tow Vehicle, Shore Power etc. The way I look at it is every time the 12v converter comes on line, it has the potential to send a surge to downstream components. I took the 12v line going to the ALDE and installed a 2 pole switch in the cabin. The ALDE is switched off until power is stable and I am ready to energize it.
2 -
@RollinWithShirley While looking for the several discussions on the "thermal fuse", I found a long thread about that subject, which also happens to have some good instructions for removing and replacing the board, if that is what you need to do.
Alde Thermal Fuse Replacement and Board Removal, etc
@madisontadpole In that thread above, there are several approaches about making a "better" fuse setup without having to solder to the board. Can you tell us more about the screw terminals you used? I would like to add that info to the above thread. Thanks for the good info!
Below is what I ended up doing. It was a one time solder to install the terminals, but once done, future replacements will be solder free. For anyone attempting this you will need a good soldering iron, good electronics solder, and a "solder sucker" for disassembly. Some of the things used were based on what I could find conveniently (amazon) knowing I had the tools and skills to modify. The first 2 photo's show the new thermal fuse screw terminals installed. The 3rd photo show the components used, and the last photo is what I found most frustrating about the whole project…In The steps were to remove the PCP, unsolder the bad thermal fuse and use the solder sucker to remove remaining solder from the PCB. In photo 3 you will see the screw terminals I bought from Amazon. it was a 2 pole terminal block that I took to the benchtop sander and sanded off 1/2 of it to leave a single pole terminal. The photo shows as it came, the box label, and the modified unit. To mount the left side terminal, there was plenty of room and an easy drop in replacement. On the right side, I ended up extending the leg of of the terminal about 1/2" (by soldering a piece of wire to it) to allow a little wiggle room to reach the contact hole and avoid the adjacent components. Both left and right were through-hole soldered from the back side of the PCB. Please note that the left terminal faces down, and the right terminal faces inward. this allowed for a "Z" shape in the leads of the fuse legs to be "stretched" and placed into the position with a needle nose pliers, but primarily, on the right side, that is the orientation that fit best. it was a tight fit with the gray component directly above.
So a quick note, the worst part of the job for me was getting the PCB removed. Photo 4 shows a hex bolt on the far left side of the PCB. it is used to mechanically hold-down the PCB to the case and would assume ground contact as well. The original fastener was a recessed allen head screw that was an absolute pain to get out with standard hand tools. I could get one in there, but the handle had to be the absolute correct length, or you could only loosen a fraction of turn at a time. A quick trip to ACE, for a metric hex bolt matching length and thread, and threw that allen head away. Now with standard metric socket and extensions it is much easier…
I have not had to try this “bush fix” but someone on this forum made a temporary “jumper by pass” for their thermal fuse that burned out while on vacation. They said it worked fine while camping and was able to make a permanent fix when returned home. I have this one made up just in case I need it while camping.
2020 TAB 320 U
TV 2025 Telluride X Type0 -
I ordered and received the thermo fuses from digikey. I am nervous about soldering them onto the control board and don't know how to find someone that might do that for me. But I wondered if I might solder one of the fuses to alligator clips on either end and bypass my current fuse following the jumper bypass example in this post.
I'm gonna probably give more questions than answers. Thing #1 …have you confirmed the ALDE works when you use a simple temporary jumper around the thermal fuse? if you have proved the thermal fuse is faulty: You are right to be concerned with soldering a thermal fuse…It's very nature is to "blow" when it gets hot. Soldering as a process uses extreme heat. As I was messing around with my fix, I tired soldering a thermal fuse "just for fun" and triggered it. That is one of the reasons I went to the screw terminal. Here is the big question. (hopefully big brain folks can chime in) What is the thermal fuse designed to protect in everyday operation, does it trip because the ambient temperature of the PCB exceeds the set level, or does it trip because the current/resistance through the thermal fuse cause the component to trip. If the safety trip is for ambient temperature, I would be concerned that the bush fix is not a good long term solution as the dangling wires get the thermal fuse too far away and not in direct contact with the PCB to accurately monitor PCB temperature. If it's protection is supposed to trip due to current/resistance, I would feel a little better about the bush fix. If you look at the bush fix device, it appears no soldering has taken place, it looks like the wire from the alligator clip was wrapped around the legs of the thermal fuse and clear heat shrink holds it in place. If I were you, I would look for PCB repair services in your local area. (google PCB repair near me) Take them the board and the fuses from digitikey and have them do it. Here is one close to me in Greenville, SC. https://circuitboardmedics.com/ hopefully you can find similar.
I
Happy Father's Day everyone. I rigged up a jumper to see if it would get the Alde going. After leaving it overnight still no heat is circulating. None of the rubber tubes coming out of the heater have warmed up, but the brass piece showed in the photo is hot. So it seems that the heater is going but not pumping. Does that mean that the jumper bypass is doing the job and the thermo fuse was bad? Is there some other obvious reason that the pump is not going?
The brass fitting is the "Auto Air Bleed Valve". If that is hot, then yes, the Alde is working. We haven't asked what year your trailer is: but, if you have the touchscreen Alde panel, you can find the "Service Menu" and it will tell you the glycol temperature, which will give even more proof.
The glycol pump starts when the Alde thermostat "calls for heat". The "requested temperature" you ask for has to be higher than the temp inside the trailer, and the Alde thermostat's opinion of the temperature inside the trailer can be quite a bit off. So, try increasing the requested temperature and see if that starts the pump going.
On my trailer in a warm state, to test my Alde pump, etc in the summer I use an ice pack on the shower wall behind the Alde screen to trick the thermostat. (The thermostat is a tiny part on the control panel board).
That is encouraging! My T@b is a 2015 so I have don't have a touch screencontrol. I have the dial turned all the way up. Any idea where I would have to put the icepack on an older model? My next trip is to the high country, so I might just install the jumper bypass when I get there and see if the heater pump will come on when the temperature drops at night.
The low temperature in Colorado Springs last night was 57 degrees.
Show us your manual panel settings. If the Auto Air Bleed Valve is warm, that means the Alde is working. On my 2017, the control panel is on the wall behind the shower. I placed the ice pack on the wall in the shower. I would suppose if you had a good way to make sure no moisture managed to get to the panel, it would work on the panel itself, also.
This is my control panel. It seems that the temperature sensor may be behind the temperature dial.
I have the same panel and I believe you are correct. I had to trick mine into starting once by blowing cold air over it.
I have waited until cold weather to follow up on this problem. The brass bleed valve is still warm and yesterday while I was in the trailer the pump suddenly came on for about fifteen minutes then turned off again. It has not kicked in again, even though current temperature is 47. Any theories about why the pump is not coming on? I almost think I would be better off bypassing the thermostat and just turning the pump on manually when I need heat. Is there a way to do that?
@RollinWithShirley said: . . . Any theories about why the pump is not coming on? I almost think I would be better off bypassing the thermostat and just turning the pump on manually when I need heat. Is there a way to do that?
Your thought that the Control Panel thermostat is not functioning correctly sounds reasonable. Have you removed the Control Panel from the wall and inspected ?
It does not appear any Owner has ever posted pictures/diagrams of the 3010-214 control panel internals nor has Alde a public publication on repairing that specific sub-part. At a minimum a good visual inspection & dust cleaning might flag an issue.
Here is the Control Panel Signal Cable pin assignments { source: Adle UK older 3010 document}
Pin/Wire # 6 appears to be the Thermostat Function.
I would assume pin6 provides a toggling voltage of 0 to ~5V to the Control PCB.- You could use a VoltMeter to monitor pin6 as the Temperature Dial is rotated. If no change suspect Thermostat circuit in 3010-214 has issue . . . a guess not fact
- Consider using a jumper wire from pin2 to pin6 (manual touching as in toggle not a hard connection) and see if the Circulation Pump starts running.
Above ideas could provide information on possible next steps.
@RollinWithShirley Good for you for sticking with this. The fact the pump came on at least tells you the main board is probably ok. Did you check to see if the glycol was actually circulating inside the trailer and back to the expansion tank? Did the hoses extending from the Auto Air Bleed Valve get warm?
MuttonChops showed the basics of the wiring on the back of the control panel. There have been owners who have changed the manual panel out for the touchscreen panel back when the touchscreen panel was introduced. There is a control cable that runs from the main board to the back of the control panel. In the past, we have seen that control cable become "crimped" where it exits the Alde board area and begins to run up to the control panel. It looks like you have all those connectors on the board well marked, but I would still take a look to make sure all those connectors are secure, and nothing seems "loose" on those push in connectors.
That control cable runs to the back of the control panel on the wall, which is only screwed to the wall with 4 screws. I would pull it out, (carefully) and check the cable that goes into the back of the panel. And, try to have a good look at the inside of the thermostat area. The old "mechanical" thermostats had springs and switches, etc, and if any of those items got dusty or corroded over time, that could be the reason the thermostat is not reacting. We do have photos of some odd things that have happened with the "touchscreen" panel thermostats, but apparently there is little or nothing on what the inside of the Alde manual control panel looks like.
@MuttonChops @pthomas745. Thanks so much for the encouragement and the advice. Yes the glucol was circulating through the hoses…..for that brief moment. I will follow up on your suggestions.
FYI, if you find that your control panel has gone bad, I have one available from a 2016 320S that had its replaced with the touch screen version in November of 2015. Basically brand new. Cable included.
Message me if you would like to have it.
Good luck, Dave
2016 T@B 320 Max S "T@BsentMinded"
2009 Subaru Outback R 3.0
2022 Ford Ranger XLT Super Cab
I examined the control cables and inside the controls and didn't find anything obvious. I wasn't sure you to test the voltage on pin 6 with the multimeter, but I did make a jumper between pin 2 and pin 6. This somehow engaged the Alde, I could here a whirring, but it didn't actually begin pumping. Do I need to try that again when the temperature is cold? In the photo you can see the insides of my control unit. Is it possible to replace this part?
@RollinWithShirley said: . . . wasn't sure you[how] to test the voltage on pin 6 with the multimeter
No worry, if thermostat is bad no voltage change would occur.
. . . did make a jumper between pin 2 and pin 6. This somehow engaged the Alde, I could here[hear] a whirring, but it didn't actually begin pumping
This is positive. Jumper between pin 2 to pin 6 places a positive "on" signal to the Alde Control PCB, that closes a relay (real or electronic) which sends 12VDC to the circulation pump. It is difficult to observe the glycol actually moving until the circulation pump has been on for some time.
. . . Do I need to try that again when the temperature is cold?
No, cabin ambient temperature is not a factor. The jumper is replacing the thermostat. Anytime pin 6 has +5V on it the circulation pump should/will run. Consider, using jumper on pin 6 with Alde Heat Power Source at the low electric settling and see if A) the glycol tubes get hot/warm after 30+ minutes and B) the circulation pump stays on.
Assuming the Alde is now working (with the jumper) you at least have a work-around until the thermostat is fixed. You could even solder a toggle switch between pin2 and pin6 so the circulation pump can be controlled without dealing with the jumper.
. . . Is it possible to replace this part?
In theory, yes. However online sources all seem to be in the UK and most don't advertise shipping to USA services. Now that you know 3010-214 thermostat is dead a better option might be:
- Contact Alde USA Support Center and ask for help.
- Perhaps replacing the 3010-214 with the 3020-623 (or similar) Digital Control Panel will be suggested.
- Adle Support maybe able to sell you parts 3010-214 or 3020-623 {with installation instructions}
Thanks. I am following up with @jananddave to see if I can get a used board from him. How difficult is the switch to the touch screen? Kee
@MuttonChops @pthomas745. Here is the latest in my heater saga. I put the jumper from 2 to 6 to see if it would heat up. I could hear that something was running in the alde and even feel some air moving out the side vent. However, the unit seemed to stop hitting when I had that connected. The brass bleeder valve went cold. When I take the jumper cable off the valve heats up again. I am also curious why you said to set the Alde Heat Power Source at the low electric settling. I don't really understand the purpose of the different settings.
@RollinWithShirley said: . . . curious why you said to set the Alde Heat Power Source at the low electric settling. I don't really understand the purpose of the different settings.
Just trying to clarify Alde Setting for the test.
To know the glycol is heating a Heat Source is needed, I assumed you did not wish to run propane source (additional complexity) and the TAB shore power is plugged into a household outlet so the lower Electric Heat setting will prevent the household circuit breaker from tripping . . . of course the lower setting does require more time to heat glycol.. . . feel some air moving out the side vent . . .
Do you mean the exterior Alde Exhaust? That would mean you have the Propane on and the combustion fan is blowing . . . cold air = no flame, warm/hot air propane burning.
. . . jumper from 2 to 6 to see if it would heat up. I could hear that something was running in the alde . . . However, the unit seemed to stop hitting[running] when I had that connected. The brass bleeder valve went cold.
This sounds like you are using Propane as the Heat Source. The Alde Sound you hear (and maybe have been hearing) could be the combustion fan not the circulation pump. After a period of time if the Alde detects a boiler over temperature, flame out, or other Propane Heat Source issue the Alde Control PCB will turn the system off . . . hence, a cold Brass Output fitting.
For each time you report "test results" including the complete setting of the wall Control Panel would be helpful in our understanding of what is / isn't working.
In a separate post, I'll include additional details on the settings and steps you should consider for troubleshooting.
@RollinWithShirley; Alde 3010 with Analog Control Panel Troubleshooting Set-up Suggestions.
TAB Set-up
Shore Power Connected, Battery cut-off Off (no battery), Adle Off- No ThermoResistor Jumper on Alde Control PCB. {earlier discussions unless you know for sure that jumper is needed to get the Brass Fitting to heat}
- Confirm TAB has 12VDC . . . does a Cabin Light work?
- Confirm TAB has 120VAC . . . will Air conditioner turn-on?
If TAB has power.
Set Adle Control Panel as follows.- No pin2 to pin6 Jumper on Adle Control Panel. {current discussions}
- Slide 1 to B (one 120VAC heater)
- Slide 2 to E (no propane)
- Slide 3 to I (HW on, Cabin Heat available) {OK for water tank to be empty}
- Dial 4, Rotate K to L (3.5) or any position above 1 {Thermostat}
Look for:
Adle will heat up Boiler Glycol, Brass Fitting. Because of the Slide 3 setting.
If after 15-30 minutes Brass Fitting has not warmed;- Change Slide 1 to C (other single element 120VAC heater).
If Brass Fitting does get warm.
Path AA
Test Alde thremostat as good/bad.- Dial 4, Rotate K to '5' . Does the Circulation Pump turn on?
Reach into the Alde compartment and touch the Circulation Pump.
You should feel it vibrating. Vibration means the pump is pumping.
If No, try Path BBPath BB
Assuming Alde thermostat is bad and Control PCB is good.- Install pin2 to pin6 Jumper at Control Panel.
Circulation Pump should turn on. The combustion fan should not turn on.
You should feel it vibrating. Vibration means the pump is pumping.Keep track of has the Alde reacts and let us know.
i am plugged into shore power, set at lower electric settings, and propane is turned off on the control panel. I can feel a small amount of cold air coming out of the exhaust vent. I just rechecked these settings and put the jumper back on. When I first connect the jumper the propane red light sometimes comes on for a moment.
i will go through your whole set of instructions. i only read the first post.
