RZRBUG
Member Posts: 890
On my last stop on the way home yesterday, I was approached by a Zombie (why is it always when you're in the biggest rush?). When I opened the door, I noticed the LP detector was beeping (LP had been shut off, so sure that was not the problem). I looked at the battery meter plugged into the 12V socket and saw that it was registering low. I had the 7-pin plugged in and had been driving that way for HOURS.
When the Zombies left, I started the truck and the meter immediately shot up to over 13V. I turned everything off I could, including the fridge, and turned the battery cutoff switch to off and drove the three more hours home. When I stopped and shut off the truck motor, the beeping started again. Being too tired to mess with it, I shut everything down and went to bed.
This morning, without connecting the 7-pin and with the cutoff switch still off, I checked the voltage again and got a reading of 12.7V, fully charged. Anyone got any ideas?
Durango, CO
2015 S Outback
And are you sure Booger didn't fart in your trailer???
Funny, Mike, although that could certainly be a possibility. I now have the T@B parked back under its shed with the solar maintenance charger hooked to it. So far, I have not been able to replicate the problem. I will check the fluids tomorrow, although I did that before my first trip this spring.
I had the fridge running as well as the ARB, but that should not be the problem. I have done so before.
I will do some checking later in the week. If I do not find a loose connection or low fluids, then I suspect it might be the Norcold as it seems to run a lot. I do need to check the 7-pin wiring as the harness is a little loose on the bumper and may have loosened a wire/ground as source3 suggested. BTW, the Norcold loses temperature at more than twice the rate of the ARB. Probably the reason it runs so much.
Thanks for the suggestions.
Happy Trails Y'all
Durango, CO
2015 S Outback
Happy Trails Y'all
A visual inspection of the cells appeared to show they didn't need water. I decided, however, to add some anyway. To my surprise, each cell held an additional one to two ounces of distilled water. I have an Interstate battery and the design is deceptive. Maybe others should try adding distilled water even if it appears it may not need it.
I currently have the trailer hooked to the TV through the 7-pin and am giving it a good charge. Which brings up another point. If you plug a voltage meter into the cigarette plug in the trailer while it is connected to the 7-pin plug, it will measure the voltage being sent TO the battery, not the actual charge state of the battery. I would assume that is also true if you are hooked to shore power, although I have not tested that theory. If you want to test the voltage in the battery through the cigarette lighter with a plug-in meter, you should disconnect the 7-pin and disconnect from shore power. Of course the only true way to check it is to disconnect from all power sources and use a voltage meter with probes at the battery.
I am not sure the beeping has been totally stopped (although it hasn't happened today), but I am confident my battery is in better shape and should hold a charge better.
BTW, during my inspections, I discovered I have added the disconnect switch to the positive side of the battery. It has been that way since I installed it two years ago. And I thought all this time I had put it on the negative side. Since it has not given me any problems and since I intend to be very careful with it, I will leave it that way for the time being. If I ever change batteries or do any additional wiring, I suppose I will switch it to the negative.
Happy Trails Y'all
It sounds like something is still amiss with your trailer and that there is another bare lead that is creating a grounded scenario. Does this condition occur each time a fuse is replaced in the trailer or does it occur via a particular event (e.g., when you plug the trailer in to shore power, turn on a light, plug in the TV, etc.)? What year is your trailer and when did you first notice this happening?
I also had some beeping from my CO2 monitor after driving a couple of times on this recent trip. The battery had a full charge on both cases. I found that airing out the T@b solved it. Is it possible that CO2 is getting in from the exhaust from my TV? In both cases, it was a warm day.
Happy Trails Y'all
I'm guessing that with the ARB and trailer refrigerator running this produces a good draw on the battery as it has been noted before that unless you have an upgraded battery system the stock battery has a tendency to run down via the frig. And in as much as the LED meters do show a 13+ volt reading when plugged into the vehicle and it is running or when plugged into a solar panel, this reading will dissipate some, drop down to a reading that Larry noted (12.7 volts) when the charge source is removed and the battery plates stabilize and spread the voltage out across the battery plates. I've observed this many times via my fixed 50 watt Renogy solar panel mounted on my garage and it's interesting as it does take a little time for things to stabilize and you can watch the LED meter change as the voltage drops.
Did you say the battery cutoff switch was Off? So the battery power is going no Where, correct? the only time there is power to anything in the trailer is when you are connected to the TV.
Or did I read it wrong.
2016 Silver Shadow 5x10 ~ TV 2016 Ford Transit 350 Wagon XLT van.
"Find the Magic in a Teardrop Trailer"
Tulsa, Oklahoma USA
Bill, now I'm confused, which is nothing unusual for me. It has been long enough that I don't remember if I turned the switch to Off, or if the above is a misstatement. Can't believe I would actually do that because it would be kinda stupid.
I haven't been camping since, but I have kept a check on the battery, kept the solar maintainer plugged in, and have had the power on for brief periods. So far, the beeping has not happened again, and the charge has been good. We'll see next time I'm out if it happens again, and I'll do some more checking.
EDIT: I've given this some more thought. First, I should say that my cutoff switch is wired into the positive side. I plug my solar maintainer into a 12V socket that I installed on my battery/LP cover. It is not connected to the cutoff switch, so I can turn it to Off and still charge the battery. Again, I may be mistaken, but I "think" the battery still receives a charge through the TV with the cutoff switch set to OFF. Since I created this confusion, I will connect the truck to the trailer tomorrow and see if that is correct and will report back.
Happy Trails Y'all
Tulsa, Oklahoma USA
I'll back my truck up to the trailer under the storage shed tomorrow and plug it in. I'll do some tests with motor running and off, and with cut off switch on and off. Let you know what I find.
Happy Trails Y'all
UPDATE TESTED: I connected the 7-pin to the trailer and did some testing this morning. Here are the results.
OUTSIDE READINGS
1) Cut Off switch off. 7-pin unplugged. Reading at battery: 12.8
2) Cut Off switch on. 7-pin unplugged. Reading at battery: 12.8
3) Cut Off switch on. 7-pin plugged. Motor not running. Reading at battery: 12.8
4) Cut Off switch off. 7-pin plugged. Motor not running. Reading at battery: 12.8
5) Cut Off switch off. 7-pin plugged. Motor running. Reading at battery: 14.5
6) Cut Off switch on. 7-pin plugged. Motor running. Reading at battery: 14.5
INSIDE READINGS
1) Cut Off switch on. 7-pin unplugged. Reading: 12.8
2) Cut Off switch on. 7-pin plugged. Reading: 12.8
3) Cut Off switch off. 7-pin plugged. Reading: None
4) Cut Off switch on. 7-pin plugged. Motor running. Reading: 14.8
With the Cut Off switch set to OFF, 7-pin plugged in and motor running, there is no interior reading, but reading at the battery shows 14.5, which should mean the battery is being charged?
As I said before, my Cut Off switch is installed on the positive side, so these results may be different if installed on the negative.
Happy Trails Y'all
Note that the power source (T.V. Alternator, Solar, or Converter) with highest voltage output will do the charging.
I don't have solar. I based this on my understanding from other postings. The solar can certainly be attached on the other side of the battery cutoff switch.
I have a feeling this diagram is a work in progress.
Dave
I was using the lights my T@B this weekend while working on it at the storage yard. My T@B battery was home in the garage on the charger and the 7 pin was hooked to my T.V. This is what I would expect based on my diagram.
Good questions. My cut off switch is located on the cover of my battery box. Operating it would be just like disconnecting the positive lead from the battery.
Both readings were taken with a digital meter that plugs into a 12V cigarette type socket (I did not use a voltage meter with probes as the plug-in meter is relatively accurate). I have one of these installed on the battery/LP cover on the outside. It is wired directly to the battery with a fused positive lead. The cut off switch has no effect on its operation. This is where I took the outside readings.
The inside readings were taken with the digital meter plugged into the 12V socket that came installed above the counter from the factory. I have no idea how or where it is wired. I do know that it is not "live" if the battery cut off switch is in the off position. In my test, with the cut off switch in the off position, there was no power inside the T@B even with the 7-pin plugged in. (See No. 3 under INSIDE READINGS above.)
Hope this helps. I had not thought about being able to power the T@B with the TV battery through the 7-pin without the T@B battery installed. Thanks for pointing that out.
Happy Trails Y'all
Beats the heck out me, Dave. My TV is a 2012 GMC Sierra that came with a tow package. The 7-pin plug was already installed. All I've done is connect the 7-pin wiring from the trailer to it.
Here's my total battery wiring setup. Maybe you can see something that I don't.
I installed a cut off switch on the positive wire of the battery.
I installed a 12V plug on the battery/LP cover. It is wired directly to the battery so that I can use it to run my solar battery maintainer, and I can use it to check the charge state of my battery without turning the cut off switch to the on position and going inside the trailer. It is fused.
I installed the special ARB plug that came with it on the battery/LP cover. It is wired directly to the battery. I can use it with the cut off switch in the off position, although I haven't done so yet. It is fused.
Happy Trails Y'all
Condo A-Go-Go
2017 Tacoma (AH GOGO)
S. UTAH
