portable grills
Hey all - I'm looking to get a new grill and was wondering what everyone had and if you are happy with it.   Thanks!!
1 - What brand/model do you have?
2 - If you were to replace it would you go with the same one or something different?
3 - Gas or charcoal?
4 - If gas small propane bottles / attach to trailer propane tank / or a separate smaller (10gal) tank?
5 - Portable table or always use the picnic table at a campground?
6 - Store in trailer or TV?
«13
  • PhotomomPhotomom Posts: 2,094Member
    We have a Weber Go-Anywhere Gas Grill that we've used for tent camping for several years. It uses one pound propane cartridge and works well. My plan is to transport RV specific stuff like hoses, chocks, and the like in the [email protected] and "camping" stuff in the SUV, like grill, camp stove, lantern, camp chairs, etc.
    John and Henrietta, Late 2016 [email protected] S Max in Western New York
  • Spruce1Spruce1 Posts: 88Member
    1. We went with the propane-powered Coleman® Camp Propane Grill/Stove. It's got a grill on one side and a burner on the other.  The grill is on the smallish side but I have cooked burgers, brats, and beans for four no problem.
    2. We're happy with it so we'd buy the same thing again. 3. Propane 4. Small propane bottles 5. Use picnic table 6 & 7 Store and haul in TV.
    2014 [email protected]
    2016 GMC Canyon, V6 gasoline, 7,000 lbs towing capacity
    Minnesota
  • JandJ92010JandJ92010 Posts: 305Member
    We prefer to cook over a fire, my wife is very good at it, and the food tastes so good.
    The [email protected], 2015-L, towed by a2014 RAM C/V
    edited October 2017
    I believe it's considered a combo unit.  We looked at a dedicated small gas grill but found this one and like it because its a stove and grill.  It's a similar size and folds up like a two burner cook stove but it has a gas grill on the right side.  The other half is a cook stove.  This gives a place to boil water, heat beans, and grill. Coleman does make a version that has a griddle; but this is a grill.  Does that make sense?
    Minnesota
  • bgualtieribgualtieri Posts: 273Member
    Camp chef butane stove - small, light, easy to start (no lighter needed). One bottle lasts us about a weekend, maybe 3 days. It rides in the tow vehicle.
    http://www.amazon.com/Camp-Chef-Mountain-Series-Butane/dp/B00A0M3B5E
    2015 [email protected] S Max | 2015 Jeep Wrangler Unlimited | was PHX East Valley, now Dallas!
  • jkjennjkjenn Posts: 5,130Member
    I have one similar to what Spruce described http://amzn.to/1LNeW96
    Jenn Grover | 2015  [email protected] S Max Silver/Turquoise Trim | 2018 Jeep Grand Cherokee Trailhawk v6 | Nights spent in [email protected]: 180 | Pittsburgh PA
    Yep Jenn, that's the one we have too.
    Minnesota
  • Mr_Mrs_GnomeMr_Mrs_Gnome Posts: 241Member
    bgualtieri, have you used your burner at higher altitudes (above 5000 ft)? If so, how did it perform?
    edited October 2015
    Well, we've used it in Payson, AZ and Siri says that's about 4900 ft. So it wasn't a true test, but close
  • BBchBumBBchBum Posts: 105Member
    Spruce and jkjenn - have you had it for awhile?  how has it held up? I've read the reviews and they are generally positive but a couple of negatives - the sides pop off and the top falls back, pan under grill is somewhat less robust - hard to adjust temperature
  • lazulibuntinglazulibunting Posts: 41Member
    I love simplicity. I have a $20 char-broil grill with the legs that lock the lid in place for storage. Uses the small propane bottles. I have three small folding aluminum tables that are stronger than they appear. (Will actually hold a dishpan full of water with no problem.) All fit underneath the back seats, and are all very light weight. I also use the large table that came with my trailer as a outside table, as I don't need it to sleep on.
    Lazuli Bunting from Utah
    2005 Dutchman [email protected] & 2010 Toyota 4Runner
    I don't use it a ton but so far, so good.
    We've used ours about 6 times this summer.  I had concerns based on some of the reviews but it's worked well for us so far.  I've found the grill side in particular to have excellent temp control.
    Minnesota
  • USWildflowersUSWildflowers Posts: 177Member
    1 - What brand/model do you have? I have the same grill as Spruce1 and Jenn - Coleman grill / stove.
    2 - If you were to replace it would you go with the same one or something different? I'd consider something different, but definitely want the combo grill / stove. I do find the flame setting difficult to control at the low end. I turn it down to the level I want, then when I release the adjustment knob, it springs back to a higher setting. To get it down to a low simmer (or really slow grill) when I turn it down to where it will stay at the level I want, the flame goes out and I've got to relight it.  I also wish it had a cut-off valve for the connection to the bottle. The side panels do occasionally release unexpectedly, but when one does the other gains enough tension so I've never had both to release and have the top fall. I usually line the pan under the grill with aluminum foil.
    3 - Gas or charcoal? 1-lb gas propane bottles.
    4 - If gas small propane bottles / attach to trailer propane tank / or a separate smaller (10gal) tank? I have an adapter for the 1-lb bottles so I can use the 1-lb bottles as a backup for the trailer tank.
    5 - Portable table or always use the picnic table at a campground? So far I've only used it (several months) on the back porch at home; busy summer so haven't been able to get away camping. Plan on using it on picnic tables at the campground mostly, although we frequently take a small table with us.
    6 - Store in trailer or TV? Plan on TV on trips; stays on our back porch at home.
    7 - Where do you haul it? Plan on TV.
    gerry - Flintstone, GA - 2015 [email protected] S - 2012 Toyota Highlander
    When we lived in Guam, I made a small "hibachi" out of freon container which I inverted and cut in half. This was for beach cooking on my pickup tailgate. The handles became the base and I cut a piece of grating to serve as the grill surface. I had to torch holes in the bottom for circulation. We liked to cook over briquettes rather than a gas flame for better taste. Due to the cost of briquettes, after cooking we would put the briquettes in an ammo can and close it to snuff them out and save them for another day. The "hibachi came home to Colorado with us. You can see something like it here: http://www.motherearthnews.com/diy/homemade-barbecue-zmaz79mjzraw.aspx
  • skwheeskwhee Posts: 243Member
    Hi Gang,
    Here's our thoughts on a portable grill:
    We just got back from another four month ramble in our Clamshell [email protected] Two years ago we picked up the Esbit Portable Folding Charcoal Grill at LL Bean in Freeport, Maine and have used it frequently in our extended travels.
    It accommodates the single use "light the bag" charcoal.  We usually grill enough meats for three or more meals for two in one session. All stainless steel construction. Easy clean-up. Sits nicely for use on a picnic table. Folds down small into it's own carry bag. We are always on the lookout for something better and just have not found anything that makes us think we could trade up from the Esbit!
    http://www.amazon.com/Esbit-Portable-Folding-Charcoal-Carrying/dp/B003DRLQEG/ref=sr_1_11?s=sporting-goods&ie=UTF8&qid=1444916549&sr=1-11&keywords=charcoal+grill+portable
    Bon appétit on the road!
    Steve and Karen Cullowhee, North Carolina 2008 Ford F150 --2018 [email protected] 400
  • JustJohnJustJohn Posts: 170Member
    I use the Eco que. It is very efficient, well made of stainless steel and folds to about an inch thick.This is a popular choice on the teardrop forum.
  • Lisa33Lisa33 Posts: 260Member
    I also have the Eco Que.  It is very well-made and uses very little charcoal (9-12 briquettes or so).   It folds down to about the size of a coffee-table book and comes with a case.  It heats up really fast and is incredibly efficient.  My first choice is always a wood fire in the fire pit, but when there is a fire ban, this is a great grill to have available and easy to tuck away.  Here it is for $47, and I think you can get a 20% off coupon online.  I paid $80ish when I bought it and still consider it a good purchase.
    https://m.opensky.com/ecoque/product/ecoque-portable-grill?target=https://m.opensky.com/ecoque/product/ecoque-portable-grill
    Lisa. 2008 [email protected], previously 2012 6x10 SS. Southeastern PA
    Thanks everyone for your input! I've learned about some different grills.
     Lots to think about.
  • FloridalohaFloridaloha Posts: 68Member
    edited June 2016
    I am a grilling fanatic and am always looking for new ways to grill and/or smoke food. I'm anticipating my upcoming [email protected] adventures by looking at some options. In college I had a portable lightweight grill that uses balled-up newspaper as fuel. It worked great, was cheap, and though they don't make them any more, I found a new one on eBay. So that will be one thing I will use for sure, it lights up fast,  and is perfect for burgers, sausages, or grilled veggies. It is lightweight and breaks down easily for transport and storage,
    But this came across my Facebook feed today, and I thought it was interesting. It's a solar grill. It comes in different configurations. I probably won't spring for one of these right away as it is kind of costly, but it looks like a great option, especially for boondocking folks or for those of us in hurricane country who might need another way to cook food until the power goes back on.  http://www.gosunstove.com/
  • rfuss928rfuss928 Posts: 453Member
    edited June 2016
    I cook on a charcoal grill 3-4 nights a week whether we are home or traveling.  We are very stingy with storage space in our [email protected] and anything that is brought along really needs to earn it keep.  I ended up with the Fire Sense Notebook Charcoal Grill.
    https://www.amazon.com/Fire-Sense-Notebook-Charcoal-Grill/dp/B001OC5PYY/ref=sr_1_8?s=lawn-garden&ie=UTF8&qid=1467322379&sr=1-8&keywords=fire+sense
    This is our second camping season with it.  It is working fine, and i really like that it folds flat to one inch thick for storage.
    Fire Sense Hotspot Notebook Portable Grill Black 192 sq in
    Bob & Rosalie Fuss - Spencerport NY
    [email protected] travels  ---
    -- 2009 Dutchman CS ---366 nights out --- 67633 miles traveled--
    States Visited Mapstatemap
    DREAM - WANDER - EXPLORE
  • tabascotabasco Posts: 23Member
    we use a COBB charcoal burning (12 briquettes)  grill.It works very well and grills burgers perfectly. keep it in the TV
    Hard to describe how it works but try google for more info.we take it everywhere in the [email protected] and on our boat! Cheers, bern and jen.
  • Fatman1966Fatman1966 Posts: 141Member
  • ericnlizericnliz Posts: 4,427Member
    Pit Barrel! =)
    2016 [email protected] MAX S-aka: [email protected]
    Eric aka: Lone Wolf  with,
    Ruger aka: Adventure Companion
  • TabsterTabster Posts: 101Member
    Coleman roadtrip with interchangeable grates/ burners. On it's built in stand with wheels. Love it. Nexgrill table top 2 burner if space in TV is tight. Coleman fold and go when it's just me going
    2015 CS. Ford f150 v8. Southern california
  • RZRBUGRZRBUG Posts: 901Member
    ericnliz said:
    Pit Barrel! =)
    Now, that's what I'm talkin' about!
    Larry & Booger - 2013 [email protected], 2012 GMC Sierra
    Happy Trails Y'all
    States Visited Map
    I have just recently decided to switch to to a gas grill (just got tired of carrying charcoal and the clean up and hassle that goes with charcoal). After a lot of research, it came down to the iconic Coleman Q or the Napoleon TQ285. I went with the Napoleon because it is a more compact design and will fit under the the rear bench on the passenger side of my [email protected] As it turns out, I carry in the TV most of the time but the carry hande, compactness, and double burners made it a good choice for me. It is a very well constructed unit and worth the price.
    JustJohn, I've tried gas grills, and food tastes a lot better with charcoal.[That being said however, to each their own!] I use what's left over in the grill to start the campfire, so really no mess to clean up. Also carry a table top Charbroil grill [like a mini Weber] when I don't take the pit barrel.
  • NomadNomad Posts: 7,215Member
    I like the taste of charcoal better but like JustJohn, got tired of carrying it around.
  • FiddlerjoebobFiddlerjoebob Posts: 6Member
    I use an old metal tool box with a grill I cut to fit.  When done cooking, I close the top and slide the box under my chair tp warm my butt.
    2015 [email protected] 320Q
    2009 VW Touareg
    Two Fiddles
    One Bicycle
    One sewing machine
«13
