New for 2016
2»
  • jkjenn
    jkjenn Member Posts: 6,425
    PXLated said:
    May have to install the digital control I've had under the seat for a year - looks nice. Completely forgot about it when I was doing my warranty repairs and had the tools.
    Wait, you have a gadget I don't have?????? :o
  • Verna
    Verna Member Posts: 6,876
    Hey, PXLated, I can try it out in my T@B to make sure it works. I'll even do the installation  =)
  • Nomad
    Nomad Member Posts: 7,209
    The reason it's not installed is you have to cut a bigger hole and make a baseplate for it.
    Was suppose to be to me on a Wednesday but FedEx didn't deliver until Friday. Threw it under the seat and hit the road 15 minutes later. When I had tools, I forgot about it because it'd been sitting under the seat boxed up for a year. This thread reminded me - "Oh ya, I got one of them"
    Jenn - As amazing as it may be, I do have a gizmo you don't have. Bet that will change soon though :-)
  • Verna
    How big of a back plate do you need? How thick, and what flavor of hardwood? Verna's wood shop to the rescue. I've been cleaning out a lot of scrap wood.
  • Nomad
    Verna - Don't know, took it out of the box just to see what it looked like and put it right back in. Just remember the email from LG at the time noting those two requirements. I think it's narrower but longer. The plate's needed to cover up the existing hole.
  • Verna
    Give me some dimensions and I'll have it with me in AZ.
  • Nomad
    When you headin out? Can't dig it out right now but will.
  • Pop-T@B
    Pop-T@B Member Posts: 199
    I sent an email to LG asking about the new Adle control panel, here is their response for those thinking about the new touch pad upgrade.
    Alde Touch Screen Panel - $162.91
    Alde Cabel for Touch Screen - $16.99
    Trim Ring - $20.00
    plus shipping
    To install this you will need to remove the current controller and connect the wiring to the touch screen panel. The trim ring, the size for the current controller is larger than the touch screen one so we need to install the trim ring for the new controller.
  • jkjenn
    At the moment I don't see a huge need for it for me.... but, you never know.
  • Nomad
    Jenn - That's why mine's still in the box - nice but not necessary.
  • Photomom
    Photomom Member Posts: 2,217
    excellent!
  • Verna
    edited November 2015
    I'll be in Gulf Shores for New Years, and I'll be out at Quartsite the 3rd week of January. Except for 4 gatherings, I'll be just going wherever.
  • Verna
    It sure is pretty in the picture =)
  • ChanW
    ChanW Member Posts: 3,165
    Does the Alde screen turn off at all (ie: no back-light, completely dark)?
  • Juslou
    Juslou Member Posts: 9
    Hi ChanW, Yes, it does when the Power button is pressed.
  • webcrawler
    webcrawler Member Posts: 133
    Very nice!!!
    Kennesaw, Georgia
    2016 Silver/Black T@B M@x S with Scuba Black interior.  2015 Lincoln MKC AWD 2.0L Ecoboost tow vehicle. Tekonsha Prodigy wireless Brake Controller.
  • davidahrens
    davidahrens Member Posts: 5
    Darn, we got our CS-S on Oct 22 and it had the old control box, not the new one. Very nice!
    Dave & Sheila Ahrens, Newport News, VA 2016 T@B CS-S Max
  • Michigan_Mike
    Juslou said:
    We have taken delivery of our 2016 Tab Max S and, as promised, here are photos of the Alde touchscreen (including ability to set a thermostat) and the Garnet tank/battery monitor. As an added bonus we discovered our Tab ("Stormy") also has an outdoor shower - very nice!
    I'd be curious to see where the SeeLevel ll tank monitor was mounted inside your trailer.  Can you post up a shot of it?
  • Juslou
    Sure, Mike, here you go:
  • Tonydjd
    Tonydjd Member Posts: 111
    edited March 2016
    Has anybody upgraded and installed the new color touch screen and what was final cost on it. Thank you. Sure does look nice and much more user friendly
    Tony D
    Central,Fl
    2015 T@B Max-S
  • Ratkity
    Ratkity Member Posts: 3,770
    edited March 2016
    Tony, are you talking about the touch-screen thermostat? I installed it yesterday. It was the easiest thing I've ever done - messy, but easy. Making the hole larger wasn't as clean cut as I could have done it with a dremel or router. The trim piece barely covered the old hole and the 2 screws holding the trim piece aren't really far enough outside the thermostat hole. I might make a new trim piece that is a little larger. I wish I could steal Verna for a few moments. I bet she could scroll some edge designs that would make everyone jealous! So much talent!!
    All I did for the install was to just pull up the copious amounts of wire from the old analog thermostat and the matching end plug to the digital thermostat was right there. Plugged it in and voila, done. There is LOTS of wire length. It's not hurting anything behind the shower, so I left it. My television isn't in that area, so there's nothing else in the way.
    I don't have the tank level thingie. Sorta want to know how it's working for those who have it!
  • Verna
    Ratkitty, I didn't use any screws, and right now the thermostat is held in by friction. I'm going to put a couple of pieces of Command Strip Velcro to hold the wood in place.
  • Tonydjd
    Thank you did you get parts from the factory. I see earlier on in this discussion thread it had a list of parts. Was not sure if this was what I needed.
    Tony D
    Central,Fl
    2015 T@B Max-S
  • Verna
    Yes, the digital thermostat came from Pleasant Valley, the factory. Call Elsie for the price. Phone number is on the right under contact numbers.
  • Nomad
    Verna/Ratkity - Does the digital plug into the current analog wiring or do you need to string it's wiring all the way back to the Alde?
  • Ratkity
    PXL, you don't have to wire all the way to the ALDE. There's an extender plug in the wall of my 2015 unit. Didn't even have to bend down and follow wire tracks.
    Yes, I called Elsie at Pleasant Valley and she'll know all the parts you need!
    Verna, friction? Ok I don't feel so bad. I doubt the thermostat is going anywhere when I bounce down the road. The larger trim piece is on the bottom of the "to-do" list.
  • Nomad
    edited March 2016
    Thanks Ratkity - Sounds like an easy switch then. One of these days I'll get around to it - Now where did I store that thing :-)
  • Verna
    Oh, that was an extender plug?  I ran the new wire all the way back to the Alde. It works, your's works--we're good!
    Ratkity, that would be a next year project for the scrolling. I hope to put my house up for sale after I get home and finish that Verna-do list. It will be another busy summer.
