I am one of the few who loves the Polar Vortex. Polar Vortex + El Nino = Big SnowstormDurangoTaB said:Jenn...hmmm...a Polar Vortex...AND El Nino...oh no! I like your idea of going to a CG with full hookups to do the draining/rinsing.
Pretty unlikely... not really a spring chicken.PXLated said:Jenn - I'm betting your enthusiasm will fade with age.
ScottG said:Just to clarify, the pump is for emptying the tank, not filling it. Once you have filled it (as PXLated described above), you run the pump to feed water from the tank into your main supply lines.
The flap thingy does not form a perfect seal. A funnel connected to a length of tubing shoved down the hole will control some of the dribbling. Also, pour slowly, as air in the line can cause it to "burp" back at you.
Thanks for that great tip jkjenn! I didn't realize it went any further than it does. I would have thought it would break if I clicked it into place. I will definitely try that!!ChanW said:robyn769, the flap 'clicks' into the fully open position (and yes, it still leaks a little). I can see how you might not have it open all the way, and the bottom would leak a lot in that case...?
jkjenn said:Camco has a hand pump for getting the antifreeze into the line: http://amzn.to/1kIHqLu
J.D. & Sue
J.D. & Sue
You are talking city water inlet, right?DurangoTaB said:Jenn...the hand pump has a nipple attachment, kinda like for the air compressor, that threads into the water inlet. Open a valve (shower or sink) then pump away til pink comes out.
J.D. & Sue
jkjenn said:They are wrong about the Alde. That is the direct opposite of what both Alde and LG advise.
An air compressor, like you would use to inflate tires or run air tools. If yu cannot limit the PSI to 50lbs, you should use your water pressure regulator to protect the plumbing.HappyCamper said:Newbie, here! What kind of compressor do you use to blow it out?
Oh, yeah, not suggesting that she not winterized, but either of them two methods should be OK in GA. I lived in Knoxville for a couple of years and saw my share of snow while there.Verna said:Jenn, it can freeze in Georgia . We had someone a couple of years ago who lived in Georgia trying to tell our owners not to winterize. You really don't want to be responsible for frozen and busted water pipes.
Happy Camper, please continue with your questions and please do winterize. Yes, it's not as cold as up here, but it just takes one freeze to bust a pipe.
