PaulaK
Member Posts: 54
Standard Bed Sizes:
Twin 39 in × 75 in
Full 54 in × 75 in
Queen 60 in × 80 in
King 76 in × 80 in
T@B Bed Sizes:
Q/S/U 70 in x 73 in (front to back or back to front)
L/CS 58 in x 70 in (wheel to wheel)
Sample questions:
a) Please identify which T@B model you own – or plan to own.
b) Which direction do you sleep?
c) Do you make up the entire bed as configured above?
Or alternatively do you make up only a portion of the bed?
d) How often do you switch between the bed and dinette?
e) Do you use the table for sleeping?
f) Do you also use the table outdoors?
g) Do you have slats and rails?
h) What type of bedding do you use?
i) What size bedding do you use?
j) How many layers do you use?
k) Where do you store your bedding when not in use?
l) Have you discovered any special tricks that work well?
m) Have you tried something that just didn’t work out?
n) Are you satisfied with the quality of your sleep in the T@B?
o) Still looking for a better solution?
p) Any thoughts or ideas that you'd like to share!
Thanks,
Paula
We own a 2015 S model and plan to sleep with our heads at the rear (but hoping not to get too many bumps on our noggins by rising up too suddenly). It seems easier to get out of bed from that position. As there are two of us we will be making up the entire bed. It takes some time and effort to make up the bed so in nice weather we think we will leave the bed made up most of the time and eat and relax outdoors.
Our T@B is not outfitted with slats so we will strictly be using our table for the bed. We have a 20 x 40 tailgating table from Wal-Mart that we plan to use outdoors.
It is a bit bulky, but my initial plan is to layer our bedding as follows:
- (bottom layer) queen size flat sheet
- 2 inch Big One memory foam topper from Kohl's - king
- old queen size lightweight comforter (mattress pad)
- queen size flat sheet (bottom sheet)
- queen size flat sheet (top sheet)
- (top layer) queen size micro plush blanket
I am trying to roll up all of the layers except the blanket to be stored behind the seat. However, it's proving to be a bit awkward to handle. One possibility is to store the "bedding bundle" in our tow vehicle.
One thing I tried did not work out. I originally thought that a queen size fitted sheet would work perfectly. It didn't. There was nothing to attach the fitted corners to so I switched to queen size flat sheets laid side-to-side. Time will tell whether or not we will wake up tangled in sheets. LOL.
Paula & Larry | 2015 T@B S M@XX "Serenity"| 2014 Subaru Outback | Maple Grove, MN
J.D. & Sue
We do use a memory foam topper over the cushions. We have the collapsible table, but I still installed rails because the table wobbles otherwise.
When it is just me camping I leave the table in place and just sleep along the back of the bed where the couch is. We almost never bring the couch upright, just leave it down. and roll the mattress, bedding and all, on top of it dduring the day.
Sterling, VA
http://www.campingworld.com/shopping/item/travasak-full-queen-62-x-80-magic-blue/75169
Also, the T@B Q bed is actually closer to 72 x 76 which makes it a King size bed (although kings are usually 80 long). We bought a King size RV Superbag and it fits perfect, the 72 width is wall-to-wall and the 80 length hangs over just a couple inches. This also gives us better coverage for those times that the little dogs con us into letting them sleep on the bed.
NO MORE MEMORY FOAM: NEW MATTRESS CAME TODAY.
When I first got my T@B, I read several posts recommending memory foam toppers for the bedding. I had never used memory foam before, but I bought a four-incher and used it for several trips. Tell you the truth, I did not like it. I know it's personal preference, but to me it was very uncomfortable.
Since I sleep wheel-to-wheel and leave my bed made up, I decided to try a regular mattress. Not being able to find one that fit the space the way I wanted, I finally found a place on the Internet that custom makes them to just about any size and configuration imaginable. They even will put a layer of memory foam inside the mattress if that is what you want.
Anyway, I ordered one to fit my needs and it came today. I placed it in the T@B and tried it out. Feels just like my bed at home. Can't wait to give it a try on my next trip. I now have an ample supply of foam padding material to keep things from bouncing together while traveling. (Your smiley face of choice)
Happy Trails Y'all
Well, yes I do, but I don't have it packed full, and I store things in there that I don't use very often. It's been so long since I've had the cushions up I'm not sure what all is in there. I think a small vacuum, a couple of citronella candles, some MRE's that I hardly ever use, etc. My spare tire used to be in there, but I mounted it on the tongue.
My tow is a truck with a cap, so I store a lot in there, and it is usually full.
Happy Trails Y'all
Silver/black 2018 T@B 320 CS-S, Outback axle, AT tires
2012 Dodge Ram Hemi - CO
Adventures: 7
States: 21
Provinces: 5
Thermarest pads
Thermarest pads
2011 T@B
Rockingham, NC
I have a similar setup with 2” memory foam topper enclosed in a duvet cover sewn down to fit. I am able to roll the mattress topper/duvet and cinch it down with 2 camping straps and as long as I remove the side cushion bolsters, I can get the roll to slide down behind the seat back. Won’t lay flat but works fine with the seat back in up position. I don’t roll my other bedding in the roll. I fold it into a quilted bag and it serves as a ‘throw pillow’ during the day.
I have a 2015 S Maxx Sofitel, so maybe the difference is in the range of motion of the seat back between models.
Christina
Our topper is latex, and heavy, so we cut it into two pads for easier handling.
Also, we got a zip-up sheet to envelope each pad as its 'bottom sheet', then we make up the top covers like a normal bed, with a top sheet, two light blankets, and a down comforter.
To stow the bed, we fold each of them lengthwise, then bungee, and 'stack' them as a backrest across the back.
(@Estancio, we bought our topper through Amazon, king size and cut it down)
