John_and_Kris said:Here is a link to an article I read. Not being electrically inclined I wonder if any one has any experience with this and would it be a good thing to do even if you generator powers the TT. We have a Honda 200i that we plan to use. www.noshockzone.org/generator-ground-neutral-bonding/
Many thanks for your advice or comments
ho-hum...
leenscottfl said:Yep ChanW when you are ignorant and not capable of learning something like I am with electricity you have to pay someone who isn't ignorant. It sucks but that's the way it is.
I have scaled back how much I do myself or the last couple of years because of the time involved. Maybe I can do something myself but it isn't always worth my time and effort. There are some things I am glad to do myself, so that I understand them battery like my battery. Stuff, though.ChanW said:Scott, sometimes it's a lot easier to get someone else to do it! I've got this problem, you see. I have to do everything myself. I end up with no time to do anything!ho-hum...
But then it's nice to be able to tell the DW how much money I "saved" by tinkering with this or that for an hour or whatever.leenscottfl said:Yep ChanW when you are ignorant and not capable of learning something like I am with electricity you have to pay someone who isn't ignorant. It sucks but that's the way it is.
It looks ok to me!
RZRBUG said:If you make one of these "G-N Bonds" yourself, be sure you bond the correct two poles. The picture in the article mentioned above looks like it may have the "Hot" and Neutral bonded together. This will cause sparks and blow fuses. Just be sure you understand enough about electricity to do it yourself, or get someone to who does. And, stop up the end where the cord would usually go with something to keep the water out.
I'm not sure what would happen if you plug an incorrectly wired one into a generator. I'm assuming the generator's built-in protections would shut it down.
sabel said:...Our local Honda dealer is having a sale on them and I'm considering a EU1000I just to recharge the battery when it's too cloudy for the Zamp. Maybe recharge the IT stuff.
I think this has been mentioned before, but the Honda battery charging feature does not have a built-in regulator. You have to monitor the charge to keep from overcharging the battery. If you hook the generator to the trailer, the trailer's converter will regulate the charge. Or, you could plug a regular battery charger to the generator then connect the charger to the battery.Ratkity said:...the Honda 2000i that has a built in battery charger... For the charger, you just have to buy the optional cable set accessory...
Great link because of the page comment. If I run my 2000ia companion in parallel with sis' 2000i, I only need one G-N plug.T@Bnero said:here is the link to progressive industries. they make a nice n-g bonding plug
http://www.progressiveindustries.net/#!generator-plug/c1mwy
mickietucs said:If I get a gen 1000, would I need the n-g bonding plug? Or is it for just those of you who have hard-wired your surge protectors?
I just read your article about creating plug for Ground-Neutral bonding. My generator has a floating neutral also, and the manual shows that… “Before connecting any loads, ground the generator with a length of heavy cable, connecting the generator’s grounding terminal to an external ground source”. They show a picture of the cable running to a metal stake pushed into the soil. However, if I use my receptacle tester, with the generator running, and grounded as they describe, with no other loads attached, the tester reports “Open Ground”. If I plug in the cord from the trailer and test with the tester, I again get “Open Ground”.
Reply:
They’re confusing earth ground with bonding. Portable generators for RVs are NOT required to have an earth ground rod at all by the NEC (National Electrical Code). A ground rod IS NOT the same thing as a neutral-ground bond, which is why you’re still showing an open ground even after hooking to a ground rod. So you should be able to build my G-N bonding plug, and create your single-point G-N bond, which is EXACTLY what the NEC requires. The information they have in their user’s manual is simply incorrect for use with an RV or any sort of home emergency power situation.
BTW, I love that you ran your own tests. It's the only way to be sure. Hope you guys are having fun in the desert. Wish I were still there.
