J.D. & Sue
Tonydjd said:I too keep close eye. I actually use dielectric grease on all those bolts and nuts to keep them from getting rusty and losing contact were it was wire crimped.
On another note for all owners OUTBACKS you need to be aware of Galvanic corrosion from two disimiliar metals meaning the alluminum platforms that are bolted to the steel frame years down the road you mave have corrosion issues.
When I installed my alluminum storage box I used rubber strips between the frame and bottom of diamond plate box to prevent this from occuring.
This seems like good feedback for the factory. Perhaps one of the moderators can pass it along. There is quite a bit of contact between the platform and frame, I believe.On another note for all owners OUTBACKS you need to be aware of Galvanic corrosion from two disimiliar metals meaning the alluminum platforms that are bolted to the steel frame years down the road you mave have corrosion issues.
