Wanderoo, your welcome. I essentially do this on my bass boat, If you don't this area will suffer in long run. Someone else here may have a better solution but this is my short term solution. Humm..a large plastic storage bin placed over this area may do a better job. Will have play with that idea.
I put mine on front to back with the help of a broomstick to lift it over the vent. I also hook one end of the bungee to the broom and pull it under the T@B that way.
Forlklift, something I forgot to mention when I read that you store your T@b on asphalt; My new storage facility since July is asphalt and they have us to park our RVs with 1 x 12 boards under the tires and tongue so it does not sink into the hot asphalt during the summer. That might be something you could do at your storage place.
June; 2013 T@b "Fant@bulous"; 2016 Jeep Grand Cherokee; one kayak and one bike
A large grill cover works great to cover the tongue and battery cover. I put one end under the hitch then the other end will slip down behind the tank/battery cover. You can bungee the end around the hitch and it stays pretty secure. I'm not sure what sizes they come in, but I got the largest one I could find. It it's too large, you can always secure with bungees.
Good info Larry had not thought of that. A big grill cover should work great, thanks.
And IACamper, Putting it on front to back would probably make it easier to get over the vent cover and using a broom stick is less hassle than a ladder.
I put the cover on solo today. I will hopefully improve. I just saw the broom handle suggestion and will experiment with that Thank you Kristi (and Verna).
The only time I've had to return a product was when I had already quickly discarded the packing it was received in. Now I wait and check product first, as I have with the T@B Cover box. After opening the cover and re-folding, I decided to just discard the box into which I would never be able to return the cover! I wont be returning it anyway. I'm sure glad the kit included the large storage bag. Nice touch.
Gil Butler, Folsom, CA, 2015 T@B M@XX CS - White with Yellow tim
I went to the hardware store today to get a grill cover for T@B's tongue but I ended up getting an air conditioner cover, which I think will work. Since my PahaQue cover fits over the accessory box, I don't need such a large cover for the tongue. I got the medium size air conditioner cover, but the small size would probably work just as well. I had to secure it in several places using bungees and shark clamps, and I hope it is secure. Only time will tell. At least it's better than nothing. )
I have attached a picture of T@B's new winter hat.
I expect to take delivery of my T@B mid December and was wondering about the pros and cons of using a cover. I can see that using a cover will keep rain etc. from getting into places where it should not be, particularly if there it is accompanied by strong winds that can drive the rain sideways. Is there any concern about abrasion between the cover and the lexan windows? I expect the cover will move a bit with wind, so I was wondering if there was any concern about causing wear on the exterior finishes. Our climate here is cooler with plenty of rain. Not much snow if any. The other option (next winter) would be to apply a good coat of gel coat protection, such as what is used on boats and fiberglass bathroom fixtures.
Jenn mentioned that she wanted to use the heater with the cover on.... I have an older tab and there is a vent for the heater on the right side that gets very hot, I did the same thing she talked about (sitting in the tab and using the heater while the cover was on), and ended up with a hole burned in the cover at the heat vent location. Not sure if the Alde works the same, but if there is a vent for the Alde, it can heat up and impact the cover.
Someone had a tip to cover the windows with plastic food wrap before putting the cover on, in order the eliminate scratching. So far, I've forgotten to do that and haven't noticed any scratching I can't live with. You might be bothered by it more than I am, however.
Thanks for all the T@B cover hints on how to put it on alone. I also thought the BBQ cover is a great idea. Jbug - I do place a piece of plywood under my tongue jack but haven't put plywood under the tires. I do have the tires covered and haven't noticed any asphalt problems. I'll keep watching to avoid any issues. Thanks to all who post. It is greatly appreciated
I have the R-Pod cover - the budget just couldn't handle the extra couple of hundred bucks for the custom cover. Can't speak to the relative quality/durability since I have no experience with the custom cover; I guess time will tell whether the R-Pod cover is less expensive in the long term. The R-Pod cover goes over the Yak rack, and it also covers the accessory box and the jack handle up front; doesn't reach to cover the end of the hitch (although I haven't tried to stretch it tightly...) The door opening "mostly" aligns, as I think someone else has mentioned on this forum. The elastic corners fit nicely under the T@b at front and back, keeping it in place well, with the straps providing extra security. While it looks a bit "baggy" it should work well at keeping leaves, sticks, bird dropping, and UV radiation off the finish of the trailer.
The idea of using food wrap sounds like a great idea. It is quite soft and would static cling to the windows, creating a protective plastic film. That's another tip to add to the winterizing list.
Hi, Wildflowers -- Thanks for your review of the R-pod cover. It's great to have another person's description and experience of a product.
IA Camper -- That's a good tip about the food wrap idea for the windows. I haven't had any scratching issues with the PahaQue cover, but I'm thinking the food wrap might be a good thing to install, nonetheless. I'm all for preventative protection!!!
Beth, 2015 Toyota Tacoma (Ramblin' Rose), 2014 T@B S M@xx (ClemenT@B)
I have the cover Cheryl posted - Amazon sells it, too. I bought mine on Woot for $50. I thought I would give it a try. Even if it only lasts 1 year, I will feel as though I got my money out of it. It is not terribly thick, so I will be interested to see how it holds up to the snow and ice.
This is probably a stupid question, but I am about toil ask it anyway. I sometimes enjopy going out to watch TV into he T@b or just to hang out for a change of pace. If I do this in the winter, it is safe to do with the heat on or is that hazard of some kind? I was thinking of just using the shore power - not the propane as I am pretty sure the propane would present a carbon monoxide risk.
I haven't been successful Jenn in finding a deal on the cover. Was this a special on Woot?
Judy and Mike - Central KY
2014 T@B S M@X towed with Chevy Trailblazer Nights in the T@B: 32
So, a lot of these posts are two years old. How well does the rpod cover work on a T@b, and did it hold up? I don't imagine it's on Woot for $50, but it is on sale now for $159. Our camper will be outside 365 days a year, and the Tab cover is a bit more...
Terry & Jody... 2025 Honda Ridgeline RTL 2016 NuCamp 320 T@B Max S
T@bbey Road Appleton, WI
I just completed my second winter with the RPod cover. There are a couple of small holes that have worn in the cover, probably where it has rubbed while flapping in the breeze. I expect it to give me at least one more winter before I'll need to consider replacing it - and then it might just need a patch or two to last another year or so.
I have to put in a PahaQue plug. I have several of their products and everything--right down to a basic tent footprint--is top quality. And I was pleasantly surprised how easily the cover slips on and how perfectly it fits. If it's within your budget, rest assured that you'll get your money's worth.
I can still crack the vent with no difficulty as I have vent cover and I would think here would be enough air from ground.
Jenn, how durable is this through winter, you're in PA, yeah? Since our future t@b will not fit in the garage by a few mere inches of clearance, we are thinking of putting down a gravel/paver stone or tile pad for it around the side of the house & covering it with some sort of cover; out of site & between the house and a small stretch of woods. Curious if this plan will hold through a CT winter that has a potential of 70 inches average total of snow & temps averaging right around freezing for most of the hard winter months.
Light a campfire and everyone's a storyteller. ~John Geddes
2017 t@b CS, silver with green trim. TV: 2017 Honda Ridgeline.
Or get a set of small wheels (no tires) and lower it just enough to roll into the garage for the winter...
....derp! never thought of doing that.
However, since hubby's truck will be new, guess who'll have to park her car in the driveway and will have to scrape off said car at 5:30am for work. Yeah, I know....but it's soooo nice to just pull out of the garage in the morning with a clean car. (I'm spoiled.)
We got the cover not so much for snow , rain, and sun but for the trees. We park it under a beech nut and larger oak trees. Spring and fall are the worst. I would like to stay on shore power with it covered to keep ready to go camping. Is it safe for the refrigerator to be on?
Sometimes I think well; sometimes I don 't think so well...
I just took my T@B PahaQue cover off today after being on since last November. Here in western lower Michigan in one of the lake effect snow belt areas, we get plenty of snow and the cover did a great job. I'm very pleased with it. I also put the battery back in after storing it in the house all winter. Everything looks good and ready to go.
Happy Trails Y'all
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
Des Moines Iowa
2016 S Max Sofitel
