What do most of you think of the textured glass finish on the bathroom door.  We thought it was great, until the first time the bathroom was used in the trailer with the lights on,  not a lot of privacy in the that little space, viewing from the outside.  The glass is a lot clearer than you think!  We resolved the issue by applying white contact paper on the inside surface of the glass door.  Just curious?
Jeff
                0 ·
(also was the main reason for buying the 2015 T@B, no exposed porta potti and they removed the sink)
I bought a cheapo full-length mirror to replace the glass in the shower door. The length is perfect, but I need to cut 1/2" off the width. I plan to mount it facing the living area and hope it will reflect extra light into the T@B as well as provide privacy in the shower. Plus, it lets a lady check her attire before stepping out for the day. It's one of my winter projects for PopT@B. If it works out I'll post pictures later. If not, I'll simply put the original glass back in the door frame. Sounds easy, right?
2014 T@B S M@xx with wetbath, aka PopT@B, silver with black trim, TV 2002 Chevy Avalanche
"Take only pictures, leave only footprints."
Became Tabbers Oct. 24, 2015
(formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
Toronto ON Canada
Does over the door storage reduce the width you can open the door? Does it bump into the sink/cupboard?
I sort of like the idea of contact paper.
I have been wanting to incorporate maps into my decor so I had a custom map of Yellowstone printed as a decal. It works because the bumps in the paper from the glass look like natural terrain elements. (The clock isn't staying)
Sterling, VA
2014 T@B-S
Just remember the contours on the glass will show through. Using a thicker vynl decal and a terrain map worked in my case.
J.D. & Sue
2016 T@B S Max, near Portland, OR
Photo Galleries www.pbase.com/jctangney
