I know a couple of photographers who use those $2.99 multi LED lights you can get at Harbor Freight. Tuck them behind a convenient rock or tree.PXLated said:Jeanne - Various LED flashlights for the outside lighting and a strobe for inside. Multiple exposures layered together in a photo editing app.
Most guides for this kind of set set-up recommend around 3500k, but it does come down to taste. It will vary depending on the light you use, though. The Bronfman Xenon should be closer to 2900k.mash2 said:Curious why the light seems "tungsten" (2,000-2,700K Calvin). The flash is about 5,000K and most LED's are in the 4-5,500K range. Color set by taste?
BTW, checked and you can get a 18M candlepower rechargeable spot from walmart for under $75. Go for it.
You mean we won't see you setting steel wool on fire and spinning it?PXLated said:I generally don't use the term "light painting" to describe the technique I use as there's just a lot of weird junk out there in that category. It's more "studio lighting" outdoors. But here's light painting in the studio and this vid shows (on a small scale) what I'm doing outdoors on a larger scale...
https://fstoppers.com/bts/behind-scenes-beverage-photography-shoot-using-light-painting-techniques-126890
https://www.youtube.com/watch?v=9B8S6YhVlzcPXLated said:Jenn - I've actually had a couple locations where spinning steel wool might have made for a dramatic background behind a structure but was afraid I'd catch something on fire. Could just see the headlines - Idiot photographer catches 10,000 acres of native prairrie grass on fire. :-)
