I searched the section but can't find my answer. We have a Lexus 2015GX460 with Tow Pck including a 150amp Alternator. I would like the TV to charge the T@B battery and run the Fridge on 12volt. Question: will it work?
South Carolina
0 ·
You didn't indicate which fridge model you have...
- If you are referring to the 3-way fridge (in the non CS models), the 12V setting draws a lot of power and will quickly deplete your battery. It's primary use is for running the fridge while towing. Even then, some alternators have a hard time keeping up (though you might be ok with your 150amp). When parked, propane is a much better option for running the fridge--it uses very little gas and very little battery power.
- If you are referring to the 2-way fridge (in the CS models) where propane is not an option, I understand they operate differently and draw far less power on 12V than the 3-way models. Maybe somebody with experience with this model can advise you on how long it will run on a battery charge.
That said...
- Your TV is an inefficient battery charger. I suspect you would do better with a solar panel, or a small generator. (And that's another thread all together!)
South Carolina
The dumb thing about the three-way is that it runs continuously when in 12-volt mode - it pays no attention to the temperature setting.
YMMV, I think.
There is a mod for the three-way, which makes it recognise the temperature setting when in 12V mode, which allows it to switch off when it reaches temperature, just as it does in propane or 120V modes. Info can be found in the Yahoo group's Files section.
CORRECTION: my mistake, it's not in the Yahoo group Files, it's here: http://webs.lanset.com/rcochran/norcoldthermo.html
I've installed it on our fridge, but it's not a simple installation. You'd need to be comfortable with electrical circuits and wiring. It's not difficult to do, but a little knowledge helps.
I just do what boo does minus putting frig on 12V. Cold food to start off with and a square water container that is frozen. I've driven 6 hours without any significant melting of frozen jug. Thermometers I have set up indicate 39-40F (where a frig should be) at the end of the drive. I put paper towels under the frozen water jug because it will sweat and the ice on the outside of it will melt off (this jug has been a fixture in my freezer for a while - used it several seasons prior to T@B-Life and it fits perfect in a 5-day Coleman cooler). It's an older jug, so I can't be sure there's no BPA in the plastic. I wouldn't want to drink water that has been frozen-thawed multiple times in such a container unless I'm lost in the desert and there's nothing else to drink.
We haven't really come up with the perfect system yet. The cooler's a pain after a few days, because everything's piled up in there.
A vertical cooler would be easier to keep organized. Will have to look into that. B-)
I usually freeze some meat and put it in a cooler box with some dry ice in it. They stay frozen for a couple of days with a cheap styrofoam cooler box.
If you want dual 6s, that's fine but it shouldn't be necessary.
I suspect the power demands of the 3way might have been exaggerated over time...
2016 Silver/Black T@B M@x S with Scuba Black interior. 2015 Lincoln MKC AWD 2.0L Ecoboost tow vehicle. Tekonsha Prodigy wireless Brake Controller.
I'm pretty sure I didn't have my Fluke DMM's "Exaggerate" switch on, when I measured it... B-)
Edit again: my mistake, it's not in the Yahoo group Files, it's here: http://webs.lanset.com/rcochran/norcoldthermo.html
(Well, we've successfully talked ourselves around in a circle now...)
