2x good idea. When I changed my TV went from a 2006 Rav4 V6 (with tow pkg) to a 2015 GMC Canyon V6 (with tow pkg), I needed the full length of chain provided by the factory to accommodate a longer hitch (in order for tailgate to clear the jack when tailgate was down).JandJ92010 said:I just unbolted mine from the A-Frame, moved the chain back a few links and re bolted them. Didn't cut the ends off in case they need to be longer again someday.
I can cross the chains on my 2015.ChanW said:Huh, the law is very specific!
Has Little Guy begun using two points of attachment to connect the chains to the a-frame now?
On our Tab the chains are connected to the a-frame with only one central link, making "crossing" the chains impossible.
I've been intending to re-do that for a couple of years!
ST_Bob said:The chain must be short enough so it cannot touch the ground under normal circumstances, even when hitting a bump. It must also be left slack enough so the brake safety switch can be pulled out by the cable which should be connected right to the tow vehicle's hitch - never to the chains. Loop it as necessary to prevent it dragging and assure it can be pulled out if the trailer comes off the ball.
I thought this was common sense. But it has to be called uncommon sense now I guess.
Yes, they have made that adjustment on the newer trailers. Still on my list to change as well.ChanW said:Huh, the law is very specific!
ST_Bob said:That's a very smart way to do it. Did you make sure the bolts were originally grade-8 bolts?
