 Michigan_Mike
                    Member Posts: 2,858
Michigan_Mike
                    Member Posts: 2,858
            This information was passed along to me by the factory and they asked that we share this with forum members, so please take a few moments to read it:
If your trailer is 1 year or older, we want to encourage you to properly maintain it. As you prepare for the camping season, it is vital that you do this – and it’s the perfect time before you start travelling/camping.
Perhaps the most important thing you can do is to check the seals. If any of the seals are cracked, you must re-caulk them. From time to time we have clients contact us with 2 and 3 year old trailers that have experienced some level of water damage. Upon investigation, the reason, more often than not, is that they did not stay on top of the seals. We don’t want anyone to experience water damage – it can lead to something ugly, like stained or swollen wood or something horrendous like an entire floor or sidewall replacement, depending on the trailer.
For those of you that have T@Bs, please pay close attention to 3 areas more vulnerable to water than anywhere else:
1. Under the wheel well
2. Behind the fender - caulk between the sidewall and wheel well – there is a great amount of flex/movement at this location and it will break the seal.
3. Under the door frame
4. Please refer to the attached photos to show exactly where we are advising you to re-seal on an annual basis.
As always, you can contact our warranty and repair departments for assistance in any matter:
warranty@nucamprv.com repairs@nucamprv.com
or here?
And for behind the fender, is it here?
Thanks for asking!
Condo A-Go-Go
2017 Tacoma (AH GOGO)
S. UTAH
Same thing in my job. They have to understand most of us are greener than green. A little hand holding goes a long way.
Also bearing maintenance, Alde maintenance, etc.
1. Door. Yes, under the silver door frame, not under the (red) trim.
2. Fender. There was no picture of that. If you look at your trailer from the side, you will need to remove the actual fender – 7 total screws. 5 on the fender itself…Be careful not to miss the 2 on the bottom that screw into the adjacent trim pieces.
3. Wheel Well. The picture of the black material with black caulk is for the wheel well. Caulk both sides.
4. Kind of caulk to use: Any caulk that is exterior protected.
South Carolina
There is a video someplace online about applying caulk to an RV. I'll see if I can find a link.
1) Wear safety goggles as you will be on your back part of the time looking up at your work. Dirt and road grime could fall into your eyes.
2) Get in a position to check out the areas with a flashlight before taking the fenders off. You may find that the original caulk is still fine.
3) If you add caulk, I suggest trying to do it without taking the fenders off first. Removing screws from fiberglass tends to weaken its anchoring capacity.
4) Have some type of container to place the screws in if you remove the fenders. They are easily lost.
5) If removing the fender(s), take the bottom screws out first and replace them last. These are the ones on each end underneath. Makes them easier to handle.
6) When replacing the screws, remember snug them up but don't over-tighten. You don't want to strip them.
7) If you really want easy access, you can remove the tires. Perhaps you could do the job next time you repack your bearings.
8) Have old rags or paper towels handy to wipe off all the dirt/road grime before applying caulk so that it will adhere better. You'll need them for cleanup.
Happy Trails Y'all
Happy Trails Y'all
It is good to hear from you again. Hope all is well.
Happy Trails Y'all
South Carolina
I believe that you can visually inspect the area (without the need to remove the fender) to see if the caulk is starting to crack John.
I have found that the GooGone spray product works excellent when removing silicone based caulk. I used it when I did work on a roof vent about 5 years ago and if you spray it on and let it sit for a while it does loosen up the caulk and you can peel it off.
