Alde AA battery back up, anyone?
i have been struggling with Alde, and only to find out my husband truns off the 12v battery when B@t T@b is not in use.  This means the Alde setting disapoear.  The only way to keep them with 12v off is to add a AA battery attachment.  Has anyone done this?  Crazy this doesn't come standard.
B@t T@b, the 2016 Max S Outback, pulled by Bane, the 2014 Honda Ridgeline.
  • Tabaz Tabaz Member Posts: 2,411
    What settings are lost?
    Outback, I would think those people who have the factory-installed digital panel may also have the pump that goes with it where the panel can control pump speed (instead of my pump that has the itty bitty dial in a T@B yoga position spot - see T@B yoga instructor for proper positioning so someone over the age of 15 is able to actually get up and move again after pump speed adjustment).
    There's also some temperature settings and on/off timer settings (with clock) that may also default to the VCR/Microwave Flashing Clock status. I haven't looked my digital Alde control panel since I pulled the battery fuse, but have just plugged in my camper to top off battery and work inside it as of yesterday.
  • skwheeskwhee Member Posts: 246
    We got a battery backup for our digital panel from the factory. After several times when we disconnected our battery we lost the setting on the ALDE controller. A couple of the settings that have to be reset when the battery is disconnected are: time, auto adjust temp at night/day, panel back light. Call Elsie, she will be able to help you.
    Steve & Karen
    Steve and Karen Cullowhee, North Carolina 2008 Ford F150 --2018 T@B 400
    Thanks skwee!! Had no idea that was an option when I upgraded.
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,040
    Anyone know if the new T@bs have this as standard?
    I'm really surprised the Alde engineers decided on this approach instead on putting non-volatile RAM on the circuit board to store the settings!
    In any case, if you have this be sure not to leave the batteries in for long periods of disuse, to prevent them leaking and ruining the contacts.
    Lithium Ions last much longer. I would suggest upgrading to them. If they can last 3 months sending a text msg every 5 minutes by a sim card and GPS tracker, then I bet they'll last fairly long with the (hopefully) minor power draw of the touchscreen thermostat (no data to support this supposition - just conjecture).
    I am not at all surprised. The Europeans are energy misers.
  • BatHusbandBatHusband Member Posts: 17
    Wait?  What?  REDuFresne.  When did this become my fault on the B@T T@B?  You told me to leave the switch off.  You said I could make a decision.
    B@t T@b, the 2016 Max S Outback, pulled by Bane, the 2014 Honda Ridgeline - REDuFresne's husband.
    May the flames from the bridges I have burned light my path going forward.
