As of now, I'm not asking for help. Time today to get out my binders, manuals and searching here for answers..
We drove 100 miles to a destination and then back this weekend. We used nothing during that time, only turned the ceiling light for short time, and the stereo, while not used, had its display on. I disconnected from the car upon arriving home. Last night I went out to take some measurements because we might order netting. No lights, no stereo display. So, I plugged into shore power and this morning I'll check things out... After my coffee. Wouldn't the travel have been enough to charge me up? I guess that is my first question to ask.
Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
0 ·
J.D. & Sue
If so, do the following:
1. Plug an LED voltmeter into the trailer receptacle and record the voltage of the trailer battery with the trailer unhooked from your tow vehicle.
2. Hook the trailer up to your tow vehicle, start the tow vehicle and check the voltage with your car running. If you have a dedicated feed to the trailer from your vehicle you should see a noticeable spike or rise in the voltage reading if your vehicle is providing a good charge back to the trailer. And if not, you probably do not have a dedicated charge line running back from the tow vehicle battery, via the alternator.
Note: Your trailer battery has a fuse on it too and you should check that out as well to ensure it's not blown.
I would open the hood and check this out too as there should be a 30 amp fuse in a fuse holder at the battery protecting the line back to your rear wiring harness of your TV. That would be a place to start, as will you plugging the trailer in to shore power and seeing if the battery is taking a charge. I would recommend you start at the vehicle battery, work your way back to the rear of your TV and ensure you are getting voltage to the rear and on to the trailer battery, then check out all connections, fuses, fuses in the electric converter, etc.
However, I question the premise that it's a battery charging problem. You were able to use the lights on your trip, so you clearly had power one day, and no power the next. That seems pretty abrupt under the circumstances.
As Mike suggested, start by checking the actual battery voltage--preferably at the battery terminals using a voltmeter. If there is significant voltage at the battery, but everything in the trailer is totally dead, that I would start looking for blown fuses or disconnected wires. Please let us know what you find!
T@bbey Road
Appleton, WI
Here's the wiring on the plug, you can check there for charge also... The black wire...
You know, some day I may take up radio controlled planes. I'm sure there is as much learning involved as this. My 42 years of tent camping were not this involved. My ice and wreck diving were though... That was just youthful craziness.. This is why they call them hobbies....
T@bbey Road
Appleton, WI
If everything is working properly again, that suggests the battery was fully depleted, but charged up overnight on shore power.
Were you running the fridge on 12 volts on the drive home? That's the only thing I can think of that would drain the battery so quickly and so thoroughly--particularly if your car is not wired for charging the trailer battery.
J.D. & Sue
T@bbey Road
Appleton, WI
Be aware though that to test the electric brake power you need something with resistance like an incadescent circuit tester.
If voltage drops abruptly--particularly to the point where your trailer loses all power--that suggests your battery is compromised. If your trailer loses power but your battery still shows a reasonable charge, I might start looking for some intermittent bad connection.
In light of comments others have made, the problem you first described could occur if your battery was not fully charged to start with, and your car did not have a 12 volt charge line. The additional load of your weekend trip could have drained the battery to the point where it could no longer provide any usable power to the trailer. Plugging it into shore power would have recharged the battery, but how long it is able to hold that charge is a better indicator of its health.
I hear ya' about the relative simplicity of tent camping...but I have no desire to go back!
Happy Trails Y'all
100 miles of a trickle charge from an alternator isn't very far for very long. I don't think you'd charge much if your battery was even half depleted. That's only an hr and a half at 60 mph (right?). A 50% depleted battery can take overnight to charge to 100% because the float cycle takes so long. You can get it to about 95% after about 4 hours with a typical car charger.
Many people have put in cut-off switches in their campers, but pulling the fuse for a while will work for me until I get my ducks in a row and finish putting in my second propane tank in and move the battery in front of the box with the group 27 size deep cycle. Then the cut off switch goes in and I remove the spaghetti I have for the solar in the front box to something neater.
Forgive me if you've already put in a cut-off and this happened and already know the above. Testing as described in above posts (I like the little 4/7 pin tester... I have an incandescent one, but can't find the sucker).
Best of luck!
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
So.. Another learning journey.
I learned:
1. I didn't have a charging from the car. I was told I could get this for $200. Worth it? Could my 6 cylinder RAV4 do it?
2. I picked up a 7 pin connector tester and know what each of these connections do.
3. I have the inexpensive charge plug-in gauge to show my battery level.
4. How fast a battery can discharge even without use. -- from personal experience and Jenn....
5. I was told by the dealer that I probably should disconnect the battery fuse when not using. I read this from one of Verna's posts a while back, but it flew right over my head, I guess..
Finally... I learned again how helpful everyone here is. Thanks!
T@bbey Road
Appleton, WI
$200? For one wire?!?!!?! *faint, thump* No wei! I put the harness and hitch on my Rav4. "Tow Package" meant, no hitch, plug in ready for the wiring harness and the alternator. That was it. Putting in the wiring harness was a piece of cake (follow driver's side kick plate to rear taillight along carpet - wires under door moldings.
The Rav4 forums were very helpful and the forums are broken down into respective vehicle years so that differences among them are separated. Wiring a 10 gauge wire to the 7 pin plug? Easy. NOT worth $200 unless you have physical limitations about getting up and down off the ground (you'll have to look under the Rav4 after you run the wire to the tail light and drop it underneath). The Rav4 forums are the place to ask specifics for your year. Best of luck!
T@bbey Road
Appleton, WI
FYI, the easiest way to tell if you have a charge line without any meters. (This method does not tell you how efficient it is).
Turn off your T@B battery by disconnecting the negative, turning the battery cutoff, or removing the fuse at the battery.
Hook your camper to the 7-pin, crank the engine. Turn on an interior trailer light. If it comes on, you have a charge line. Turn off the engine, if the light goes out, you have an isolation relay. If the light stays on, you do not have an isolation relay.
Dad and myself installed the charge line and isolation relay, and a 7-pin setup to my first truck. (It already had a 4-pin). About $50 worth of parts including the 4-pin to 7-pin changeover. It took us about 3 hours.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
T@bbey Road
Appleton, WI
